Tachometer Problems
Old Nov 29, 2006 | 12:49 PM
Newtmaker's Avatar
Default Tachometer Problems
My tach is acting crazy. It only starts after a couple hours of driving, and then slowly the indicated rpm's will creep up, as much as 1000 rpm over where it actually is. Please note, this is not the engine actually increasing rpm, just the indication the tach is giving.
Yesterday, I stopped after it was up to a 1000 rpm high and shut the engine down. The tach was still indicating 1000 rpm. It stayed that way several minutes, so I continued on. Later, after it had been shut down for an hour or so, it was back to normal.
Any reports out there on similar problems?
Walt
Old Nov 30, 2006 | 01:25 PM
violent_b's Avatar
(spooky music playing)
have you done any mods lately that could of affected the gauge cluster or the tach?
Old Nov 30, 2006 | 04:49 PM
Newtmaker's Avatar
Nope, Never even had it off the dash.
It must be just sticking for a while, and then returns to the correct zero position after a while.
Walt
Old Nov 30, 2006 | 06:12 PM
violent_b's Avatar
is it still under warranty? might be time to take it back to the dealer if so.
Old Nov 30, 2006 | 09:15 PM
Newtmaker's Avatar
No, unfortunately it has 42K now. I'm really not worried about it, as I know it is just a mechanical problem with the gauge itself, not an actual engine or tranny problem.
I was just wonderibg if anyone else had a similar problem or if there had possible been some type of factory tech note or tip issued.
Walt
Old Dec 1, 2006 | 12:09 PM
violent_b's Avatar
maybe your xB is trying to tell you that it wants to go faster.
Old Dec 1, 2006 | 02:33 PM
xbc's Avatar
xbc
Its that time of the month for your XB. Very moody, always up and down.
Old Oct 27, 2007 | 03:58 AM
NJTrout's Avatar
Default Re: Tachometer Problems
Did you ever find out what the problem was?
I had same problem yesterday on an '05 xA. Tach went about 1000 over normal. Also gas gauge pegged to FULL. Saw this while driving on interstate at 70 mph. Pulled into rest stop turned car off, waited about 10 minutes and restarted. Gauges now read where they should.
Would like to know what caused this. I have extended GOLD warranty and 65K highway miles on it. Never modified. This is the FIRST problem I have ever had with the car.
Thanks,
Andy
Walt
wonderworm
Nov 19, 2023 01:44 AM
Inazuma
20
May 3, 2023 01:58 AM
toyotaisme
Jan 10, 2015 10:24 PM
