Does anyone have a return setup.
Old Nov 29, 2006 | 08:55 PM
318_tC's Avatar
Default Does anyone have a return setup.
Does anyone have a return setup on the tC? What parts are using. I need some insight on this, whos done it??
Old Nov 29, 2006 | 11:59 PM
soros151's Avatar
watching
Old Nov 30, 2006 | 12:32 AM
deathbyc4's Avatar
i do, stock fuel feed to fuel rail with fitting welded on, ss braided line to aeromotive fpr, the n ss line back to fuel tank.
Old Nov 30, 2006 | 04:00 AM
soros151's Avatar
Niceeeeee!
Old Nov 30, 2006 | 04:21 AM
XD40tC's Avatar
Ok so what does this do? I need to up my knowledge!
Old Nov 30, 2006 | 04:27 AM
soros151's Avatar
Better fuel tuning? Since u will be able to control the fuel pressure.
Old Nov 30, 2006 | 04:41 AM
XD40tC's Avatar
Im not denying this works or anything but I thought the injectors controlled how much fuel went in.
Old Nov 30, 2006 | 04:43 AM
soros151's Avatar
But with this, u will control the PRESSURE. The injectors define how much can enter, but the ECU controls how much of what can enter goes.
Old Nov 30, 2006 | 12:45 PM
Prototype_xB's Avatar
Does the intank pump need to be modified in order to return fuel into the tank?
Old Nov 30, 2006 | 01:20 PM
318_tC's Avatar
Yes.
Ok deathbytc, what are u doing to block the stock fpr.
Old Nov 30, 2006 | 02:47 PM
XD40tC's Avatar
understood! thx
Old Nov 30, 2006 | 04:46 PM
ERIC-TC's Avatar
I don't understand what the objective is here. Folks have been running 550cc injectors with stock fuel pressure with little no issues. You can't play with the fuel pressure to fool the ECU cause it knows what the A/F is and will simply reduce the milli-second on the injector duration pulse to get you back to stoichiometric it does not really matter what the fuel pressure is. Piggy back is less expensive than adding a fuel pump, FPR and converting the fuel-rail to support a return line , plus the piggy-back is easier to tune for open-loop injector control. I guess if someone has a fully built engine and is running out of fuel on the top end -but I'm not aware of anyone who is running that much power on the tC.
Old Nov 30, 2006 | 04:52 PM
318_tC's Avatar
^uhh dude i maxed out my injectors and ____, im running alot of boost home boy...im not on stock block, just my tranny cant stay with it. Thats why im doing this for my build and ditching the auto.
thanks for the help...sike
Old Nov 30, 2006 | 05:08 PM
toyotaracer9's Avatar
Originally Posted by 318_tC
^uhh dude i maxed out my injectors and poop, im running alot of boost home boy...im not on stock block, just my tranny cant stay with it. Thats why im doing this for my build and ditching the auto.
what size injectors did u max out ?
Old Nov 30, 2006 | 05:12 PM
318_tC's Avatar
Old Nov 30, 2006 | 05:14 PM
was those 550s on a stock fuel pump ?
Old Nov 30, 2006 | 05:20 PM
318_tC's Avatar
Yes.
Old Nov 30, 2006 | 05:23 PM
im willing to bet the fuel pump was not able to keep up . have u ever ran the car in the 1/4 or dynoed ? I just really dont see maxing those injectors with anything less the 320whp
Old Nov 30, 2006 | 05:25 PM
318_tC's Avatar
How would I know the injectors are maxed...
Old Nov 30, 2006 | 05:27 PM
how would u know what ? the car is gonna need more then 550s to run 500whp anyway . unless u use a supplemental injector .
