HELP
Old Dec 3, 2006 | 11:22 PM
TtownXB's Avatar
Default HELP
im having lots of freaken trouble.
first my front tires are completely bald, car not safe to drive.
and then i put this one spare tire i have, and it rubs soooooooooooooooooooooooooo much.
i seriously need help.
Old Dec 3, 2006 | 11:33 PM
Kahuna's Avatar
Are your tires bald because of your recent drop? Or were they bald before hand?
Old Dec 3, 2006 | 11:40 PM
ScottsdaleTC's Avatar
I have a set of Fuzion 18 X 8 with about half the treed life on them. They are for sale cheap as I need to clean out the garage, lots of spare parts that have to go. If your running 18X8 let me know,
Old Dec 3, 2006 | 11:45 PM
TtownXB's Avatar
tc = 5 lug
xb = 4 lug.
no they were getting bald before drop.
i get a oil change about every month cause my car is driven everywere. so they get worn out fast.
all im looking for is someone to help me figure out WHY it rubs with a stock tire, and not with my upgraded tire.
Old Dec 3, 2006 | 11:54 PM
Originally Posted by TtownXB
tc = 5 lug
xb = 4 lug.
I have the tires only, if your looking tires only i have them.
Old Dec 4, 2006 | 02:11 AM
n2htwlz's Avatar
Scion Apocalypse
What size rim and tire are you running?
Mainly how wide is the rim, and the tire size..
Old Dec 4, 2006 | 02:19 AM
geckolyn's Avatar
I'm with Chris, your not running a negitive wheel setup are you?
Lyn
Old Dec 4, 2006 | 03:26 AM
Kahuna's Avatar
Maybe the overall diameter of the stock setup is more than your aftermarket setup?
Old Dec 4, 2006 | 03:30 AM
n2htwlz's Avatar
Scion Apocalypse
^^thats what im wondering. On my xb, I am running 205/40/17's which are the same diameter as the stock tire size.
Old Dec 4, 2006 | 03:39 AM
TtownXB's Avatar
my performance tire is 215/40/18
idk what my stock tire im using, cause its on the wall side of the garage.
i can have that tomorrow.
Old Dec 4, 2006 | 05:34 AM
Crispyxb's Avatar
215/40/18 seems like alot of rubber for an 18. I would recommend going to a 215/35/18. Rougher ride, but a better fit. thats what I have.
Old Dec 4, 2006 | 05:50 AM
Tomas's Avatar
Admin Emeritus
Old Dec 4, 2006 | 11:52 AM
n2htwlz's Avatar
Scion Apocalypse
^^^thats an awesome chart for comparason^^^ thanks Tomas...
Looks like your perf tire is 26mm larger in diameter than your stock tire.
Is your stock tire rubbing the inside fender edge or inside the fender well, like when you turn.
Old Dec 4, 2006 | 07:52 PM
Tomas's Avatar
Admin Emeritus
Yeah, it's a decent chart, and gives a really quick check on sizes. (Doesn't mean they will fit, only how the diameter compares.)
I've posted it up here a dozen times or so...
Tomas
Old Dec 4, 2006 | 09:14 PM
DOHCtorJT's Avatar
Dude you're on coilovers. Crank that puppy back up until you can get proper tires. No sense in being unsafe with bald tires and rubbing issues.
Old Dec 4, 2006 | 09:22 PM
Crispyxb's Avatar
So are the highlighted ones the size that is recommended?
Old Dec 4, 2006 | 09:31 PM
Tomas's Avatar
Admin Emeritus
The highlighted ones are the ones that are essentially the same diameter as the OEM xB tires. That is neither a 'recommendation' nor an assurance they will fit without interference.
(BTW, the OEM bB tires are 18mm larger than the stock xB tires - they are 185/65R15. That is the size I am running. Makes the speedo on mine 'right on' but increases the odometer error - in my favor...)
Tomas
Old Dec 4, 2006 | 09:59 PM
Crispyxb's Avatar
Thanks, cause my size is highlighted, and I dont have any trouble with rubbing or my speedo being off.
Old Dec 4, 2006 | 10:59 PM
dagarhart's Avatar
Scionetics
How many miles do you have on your tires? And when was the last time you rotated them? Tires should be rotated around 5000 miles.
My guess, if you are having to change your oil every month that you are due to rotate your tires every 2 months. Being front wheel drive, you may have been over due for tires. Just a theory.
Old Dec 5, 2006 | 02:14 AM
TtownXB's Avatar
ugh well i replaced the front tire cause it was flat before, but it was got just as long as my older one.
im getting new tires on wednesday.
nitto neogen tires.... good?
