Rim setup Question
Old Dec 6, 2006 | 03:28 AM
dmpsk8's Avatar
Default Rim setup Question
so im lookin to get a pair of 17s for my box but I'm new to wheel setups. I saw the buyers guide for wheels awhile back but not quite crystal clear on everything. I'll have a 1" drop on my box and not sure what the offsets should be. Heres what im thinkin about:
Old Dec 6, 2006 | 04:24 AM
JUANG's Avatar
17x7 Or 7.5 should fit ok, a 1" Drop should not make a difrence on how it fits.
You should test fit the wheels before you buy, A good wheel shop could help you
Old Dec 6, 2006 | 05:44 AM
sizzlinscion's Avatar
if you go with a 17 x 7.5 with an offset of +42 you will be fine. Any offset bigger than that you will need spacers to clear the shock. You may want a spacer anyway so i will put the wheels flush with the fender (it looks alot better that way).
17 x 7 you should have no problems at all. A 1" drop isnt much so you should be fine with that. You could get a 45 series tire with those rims and still have no problems.
Old Dec 6, 2006 | 01:03 PM
TerribleTed's Avatar
The only problem with spacers is that they negate the use of the hub rings used on some aftermarket wheels to get good hub centering, as well as negating the hub centering circle on wheels that dont need the hub rings. This can lead to a slight vibration since the wheel may not center perfectly on the lugs alone. May well be worth it for the look (or clearance if you need it). I had spacers on the rear of my 1972 Suburban and if I installed the wheels and noticed a vibration, I would loosten and retighten the wheels (therefore slightly changing the centering on the lugs) a time or 2 which resulted in minimized vibration form this source. (hadda find the "sweet spot"). Not saying dont use spacers but food for thought anyway.
Old Dec 6, 2006 | 02:17 PM
dminner's Avatar
I live close and have a set of wheels with a similiar design for sale.
https://www.scionlife.com/forums/viewtopic.php?t=150247
They have a more agressive width and offset than what you will find with those enkies. They are 17x8.5 so they have a lot of lip, and the offset is +25 so they will sit nice and flush with the sides without using spacers. Additionally, rubbing wont be a concern, I am lowered a little lower than 2inchs and have never rubbed.
Old Dec 16, 2006 | 09:10 PM
bB2NER's Avatar
Music City Scions
17X7 or 7.5 with 42mm offset is about perfect. Use 215/40 or 205/45 tires and you should have zero rubbing issues with a 1" drop. Forget spacers unless you want problems.
Old Dec 17, 2006 | 12:26 AM
RTon20s's Avatar
This isn't the case with the spacer most often recommended for the xA/xB. These are actually hub spacer, and not wheel spacers. They go behind the hub, not between the hub and the wheel.
And I have never had to use hubcentric rings on a set of aftermarket wheels. This could have a lot to do with the installation as well. I do it myself, and watch if they ever have to be pulled off for service. A properly mounted wheel that has been balanced should not have any vibration problems. Even without hubcentric rings.
Old Dec 17, 2006 | 02:36 AM
Yeah the hub rings are really just insurance. They make sure that the rims center on the hubs even if some jackass tightens them unevenly
Old Jan 9, 2007 | 03:23 PM
jsa3mm's Avatar
Sorry to reopen this thread, but I was wondering if anyone knows the best offset to get the rim as flush as possible without any spacers. I want to run 15 inch rims.
Old Jan 11, 2007 | 12:27 PM
RedFox180's Avatar
Try 1TDA.com
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
Male_Nurse
Sep 27, 2003 10:59 AM
