problem with belt rattle after installing nst 9lb pulley
Old Dec 6, 2006 | 04:52 AM
cmcpride's Avatar
Default problem with belt rattle after installing nst 9lb pulley
I'm haveing problems with my belt rattle after installing nst 9.5 s/c pulley .I replaced belt with the recommended part number from nst web .Has any one experienced this problem. I already replaced belt tentioner, still rattles at start up .
Old Dec 6, 2006 | 04:01 PM
Garage1217's Avatar
Never heard of a belt rattle, most likley you are hearing a rattle on cold startup from the end bearing assembly. It would be slightly louder running more on the bearings at startup. It is nothing to worry about. Vortech designed the end unit for thermal expansion and once things heat up a tad the rattle sound goes away correct..?
Old Dec 6, 2006 | 10:56 PM
njdan69's Avatar
ScionERA
Is the new S/C pulley aligned with the rest of the pulleys?
Old Dec 6, 2006 | 11:22 PM
-NEMESIS-'s Avatar
check the tensioner. I had a rattle turns out that the stud holding the bottom part of the tensioner shock was broken.
Old Dec 7, 2006 | 05:13 AM
cmcpride's Avatar
YES S/C PULLEY ALIGNED, CENTER, I ALREADY REPLACED TENTIONER ONCE ,IT REPAIRED RATTLE PROBLEM BUT WITHIN ONE MONTH IT STARTED DOING THE SAME THING . I'M THINKING BELT MIT BE TO LOOSE (LONG)
Old May 13, 2007 | 05:59 AM
ExEr101's Avatar
did u ever get that belt rattleing to go away? I'm replacing my sc pulley and I was looking for some info on removing it and removing the belt. Can someone please help me with it I don't have 75 dollars to have someone install it for me. thanks for your help.
NonStopTuning
Jun 29, 2015 07:42 PM
NonStopTuning
Jan 20, 2015 05:20 AM
TheTripleC
Jan 4, 2015 06:46 PM
vitkh
Nov 30, 2014 02:27 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
