Wiring In Parallel Question
Old Dec 8, 2006 | 11:10 PM
Rizzie's Avatar
Default Wiring In Parallel Question
what up I just recently installed my kicker solo baric l5 12" with my alpine mrd-m605 amp. It hits hard but I dont think its hitting as hard as I thought 600 watts to be. I dont know if I wired in parallel right so let me know please.
I took the positive wire, ran it through both positive coils. All I did to the wire was expose it so the coils could clamp onto it. Didnt cut the wire or anything except for exposing it to the coils. Hopefully that makes sense. And I did the same for negative. Now is that the right way or is it completely wrong??
Old Dec 8, 2006 | 11:30 PM
ProshopXB's Avatar
Yes that is the correct wiring for a Dual 4 ohm voice coil to run at 2 ohms.. Your L5 is a Dual 4 ohm correct?
SquallLHeart's Avatar
hmm.. they way you described it is exactly what wiring in parallel is.
i don't know much after that... such as why it's not hitting as hard.. etc...
Old Dec 8, 2006 | 11:49 PM
Rizzie's Avatar
me neither i dont get it. so i guess all the wiring is correct and everything. I guess it has to do with the amp settings. Ill go mess around with it and see what I can get but im still in the break in period of it so i aint pushin it too crazy
Old Dec 9, 2006 | 05:47 AM
llblutigerll's Avatar
wat u did was exactly how u would parrel a speaker coil
Old Dec 9, 2006 | 03:21 PM
polishstud's Avatar
Here is a wiring diagram for your speakers.
Just select the speakers you have and you will notice that you can wire them in Parallel in more ways than one. And every way gives you a different Ohm amount.
http://www.the12volt.com/caraudio/wo...igurations.asp
See if that helps in any way
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
2002cbr600f4i
Dec 6, 2003 02:01 AM
