ECU question HKS F-CON IS or Unichip for Supercharged tC
Old Dec 10, 2006 | 10:13 PM
blackdragon's Avatar
Default ECU question HKS F-CON IS or Unichip for Supercharged tC
Ok I am gettting my TRD Supercharger installed on Tues. (YES !!) , and I am planning on getting a piggyback computer to get the most out of my setup. I already have exhaust, wires, pulleys, CAI , s-pipe, mid-pipe and all of that, so I am really looking for power. I opted no turbo because I want the warranty. That being said my debate is over the Unichip or the new HKS F-Con Is. I am leaning to the HKS, because of their long history of great perfoemance. I am also hearing great things about the Unichip. The Unichip will come PNP, pre-tuned. The HKS I will have to get tuned, and I don't know if there is a harness made for the tC or a compatible Toyota. The prices are very similar so it is a hard debate. I plan also on running one of the 12lb pulleys so I need what is going to be the very best quality. You guys always have great info so I need your help.
Old Dec 10, 2006 | 10:21 PM
krdshrk's Avatar
You're going to have to get tuned regardless.
I'd say go with the GReddy EManage Ultimate - Dezod makes a PnP harness. You will probably find it easier to find a tuner for it too.
Old Dec 11, 2006 | 01:44 AM
tCtuner's Avatar
Ummm.... not to be a kill-joy or anything, but if you plan on doing those mods to the SC, you can just about forget your warranty.
Check around the boards... there is a load of posts of folks who got hosed by their dealerships or TRD (some rightly, some wrongly) for mods...
just be careful... thats all.
Old Dec 11, 2006 | 02:58 AM
soros151's Avatar
Pulleys for S/C= Bye Bye warranty, also Yes to get an e-manage Ultimate, way easier. Also, I haven't seen an F-CON used for the tC. Most F-CON are used with RX-7s and such. But if u go that route, then GOOD LUCK.
Old Dec 11, 2006 | 11:46 AM
BalistC's Avatar
If you can get your hands on the kit before the shop does pull out the tamper proof pulley cap. Also make sure that you keep all the OEM SC parts to put it back to stock should you need to. Good luck and I look forward to your build up!
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
elzy0000
Jan 16, 2004 04:31 PM
