When Porting the stock IM, what gasket?
Old Dec 11, 2006 | 06:46 AM
soros151's Avatar
Default When Porting the stock IM, what gasket?
If the stock intake mani is ported, what could be used to gasket the IM and throttle body together? Make a new gasket the old fashion way?
Old Dec 11, 2006 | 10:09 AM
toyota_scion_tc's Avatar
The stock gaskets are actually O-rings so you will not be able to use anything else
Old Dec 11, 2006 | 11:49 AM
PghtC's Avatar
yeah you will have to use the o-ring, it just limits you on how far you can port. So don't port too close to the gasket.
Old Dec 11, 2006 | 07:56 PM
soros151's Avatar
There isn't enough space, this is the same gasket used on the stock manifold.
Old Dec 11, 2006 | 09:37 PM
PghtC's Avatar
yet another reason why you need a custom built intake manifold.
Old Dec 11, 2006 | 09:42 PM
soros151's Avatar
I see that maybe it can be streched to maybe 1mm more. Like from 55mm to 56mm. :D
Old Dec 11, 2006 | 09:46 PM
PghtC's Avatar
probably not worth it.
Old Dec 11, 2006 | 10:34 PM
soros151's Avatar
I know, that's why I did the face. :D
Old Dec 20, 2006 | 02:51 AM
soros151's Avatar
Well, I was thinking, maybe we could fab a gasket of our own using maybe a metal one with rumbber inserts for the press-down part on the gasket, or maybe made from a normal gasket insert with addhering the rubber part for seal on the cut-down part.
wiltonhall
Jun 23, 2025 10:09 PM
ERZperformance
May 13, 2015 11:36 PM
SloTC1
Apr 2, 2015 07:11 PM
PTUNING
Dec 6, 2014 03:58 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
