New TRD part!
Old Aug 7, 2004 | 12:28 AM
mchlhotrod's Avatar
Default New TRD part!
New TRD Heavy duty clutch for the TC was just released...must pick this up , but i wanna wait and get it when the short shifter kit comes out also... i might just get it all at once...Clutch, Shifter, Supercharger!
Old Aug 7, 2004 | 12:30 AM
Nick_AGP's Avatar
Why would you want to pick up a clutch when the factory one works fine? If yours in worn out already, then fine, but I can't see anyone wearing out a clutch since the car came out. A performance clutch will over no advantages on a near stock car. If you supercharge it, and the clutch becomes an issue, then get a clutch.
Old Aug 7, 2004 | 12:32 AM
tckurt's Avatar
N.G.S.O.
sweet can't wait to get it... and its only 493 which I can get cheaper must likely...
Old Aug 7, 2004 | 12:35 AM
mchlhotrod's Avatar
because high performance clutches haves a shorter span that you have to press the clutch pedal...which in turn gives you quicker shifts, along with the greater gripping power. Agreed i dont NEED it right now since the car has 500 miles on it, but i like getting goodies, and i get carried away...but dont we all?
Old Aug 7, 2004 | 12:41 AM
Rivulent's Avatar
Don't forget to add they don't last as long as stock!
Old Aug 7, 2004 | 02:34 AM
JasonH's Avatar
This is not always true. It's also not true that a stronger clutch requires more clutch pedal effort. About the only thing that is almost a given is that it will have more gripping power. It also might have harder friction material, which would actually make it last longer than a stock clutch.
On a stock engine with a good clutch it will offer no benefit.
Old Aug 7, 2004 | 03:00 AM
2JZ's Avatar
2JZ
true... it's like going overboard and getting every bolt on product just to feel good that you're modding your car when you plan to get forced induction anyway. i say hold off on it. all you're goona do is just give your left calf muscle extra strain.
Old Aug 7, 2004 | 05:49 AM
OompaLoompa's Avatar
Id much rather see the release of a TRD flywheel.
ColonelSanders85
Mar 3, 2015 03:31 AM
JPuehl
Jan 10, 2015 01:01 AM
TheTripleC
Jan 4, 2015 06:46 PM
TRDSCIONTC06
Dec 31, 2014 10:12 PM
minter66
Dec 15, 2014 01:45 PM
