Is the Odometer correct?
Old Dec 15, 2006 | 11:16 PM
TongMan's Avatar
Default Is the Odometer correct?
When I changed my rims to 19" from 17" and I travelled 200 miles, Is it the same distance on both size rims?
I would assume "no." Anybody got any info on this?
Old Dec 15, 2006 | 11:52 PM
engifineer's Avatar
It all depends on the profile of your tires. The overall height of wheel and tire is what you need to know.
Old Dec 16, 2006 | 12:04 AM
SquallLHeart's Avatar
^^ yup.. what size are your tires??
you need to have a smaller profile to maintain the same circumference.
Old Dec 16, 2006 | 12:06 AM
TongMan's Avatar
on my 17" rims the tires are 225/45/17 and on the 19" rims the tires are 215/35/19.
Old Dec 16, 2006 | 12:10 AM
engifineer's Avatar
You should be ok then. Here is the way to get an idea:
The profile percentage (35, 45, etc) times the width (215,225, etc) equals the profile. Unless my quick calcs are off, your overall profile is 1 inch lower with the new tires, meaning two inches overall. You went up 2 inches in rim diameter, so the overall diameter should be the same (approximately). Now, with all of that said, I have seen this be off a bit depending on manufacturer and the way they measure. But you should be close enough that your odo isnt too terribly off.
Old Dec 16, 2006 | 12:12 AM
well.. even with the 225/45/17
there was a 1.45% difference vice the stock 215/45/17
now basing off the 215/45/17.. the 215/35/19 has a 1.25% difference
making the speedometer read that much slower.
meaning... you're going slightly faster than the speedo...
Old Dec 16, 2006 | 12:15 AM
TongMan's Avatar
how much faster? would you say 1-2mph or 5mph?
rrimportracer's Avatar
yep man you guys are fast i was just about to say that, whip out my calc and do the math, and actually a lil but makes a bigger difference than you think, on my old car i had 185/65/15 stock size and i was planning to sell, i needed new tires though so i got 195/65/15 and it was off by 5 mph
Old Dec 16, 2006 | 12:19 AM
engifineer's Avatar
225 * .45 = 101.25 mm
215 * .35 = 75.25 mm
This means the profile height went down 26mm/25.4 mm per inch = 1.02 inches
Multiply this times two (top and bottom if you will) = 2.04 inches decrease in profile with a 2 inch increase in wheel height
Now, like I said, I have seen the way the measurements are taken vary slightly from manufacturer to manufacturer (for some reason) and even tire to tire. But if I am calculating correctly, you should have almost broken even
But... I am not really a tire manufacturing guru... and I have spent a while soldering tonight, so I could be missing something
Old Dec 16, 2006 | 12:21 AM
^^ careful with those fumes.. ..... whoa.... heheh.. i think i'm gonna go brain dead or die from lead poisoning...
it's cumulative... it's a 1.25% difference
if you're going 20.. you're actually going 20.25
if you're going 100... 101.25 in real life.... yeah... not that big of a deal..
1mph difference if you go over 100..
but over a long long period of time.. sure.. the odo's gonna be off... by much? neah..
Old Dec 16, 2006 | 12:24 AM
TongMan's Avatar
Well then. If the 19" rims w/ 215/35 tires are actually smaller in diameter than the 17" rims w/ 225/45 tires, then performance-wise, the 19" rims will be better for drag racing?
I know that weight of the rim makes a difference, but I hear that the OEM rims weigh like 22lbs which is the same as the 19" rims that I have. So is it true in my situation?
Old Dec 16, 2006 | 12:26 AM
easiest way to test it out is have a friend with stock tires and wheels drive next to you at 50mph, or whatever you want, and see what your speedo says
Old Dec 16, 2006 | 01:31 AM
engifineer's Avatar
Well, reading my calcs above, your new setup should be .04 inches shorter.. so not a big difference. About 1/8th inch difference in circumference. Keep in mind, I am comparing your old to your new tire size. Not your new vs old vs 215 stock
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
oldcodger
Scion tC 1G ICE & Interior
Dec 24, 2015 09:46 PM
Klunkerbill
Nov 9, 2015 11:39 PM
Blunderbuss
Oct 8, 2015 04:56 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
