xb head swap
Old Dec 17, 2006 | 05:45 PM
Xblozv's Avatar
Default xb head swap
i searched this and either i suck at searching or nobody has any questionss about thisso here i go.
is it possible to swap the head from a celica gts on to the xb block like the honda guys do with there "ls vtec" head swaps? and if so what would be invloed with doing this? and is the bottom end even able to hold the rpm needed to make this possible.
Old Dec 17, 2006 | 06:04 PM
bbcrud's Avatar
Scionetics
Default Re: xb head swap
Here's all I could find. Maybe the people in these threads could help you find your way.
1ZZ-FE swap
I would think a performance shop would be the way to go. Maybe they already have a plan for the 1.5
Old Dec 17, 2006 | 06:16 PM
Xblozv's Avatar
i read that one and i was just wondering about just the head. thanks :thumbup:
Old Dec 17, 2006 | 07:25 PM
bfurches's Avatar
nope, wont work. The engines are WAY to far off. I have pretty much come to the conclusion that other than expensive, expensive, swaps the only way to make decent power on these cars is to go f/i with some type of engine management, preferably standalone (which all this gets price as well. Im working on my turbo kit as we speak.
Old Dec 17, 2006 | 09:13 PM
Xblozv's Avatar
hey thanks. i was just trying to think of ways that i could make it faster w/o the use of forced induction.
Old Dec 17, 2006 | 09:57 PM
Withaquicknes's Avatar
im wondering about using the 2nzefe turbo head. at least i think thats what the 2nze is over in japan
Old Dec 18, 2006 | 03:06 AM
Xblozv's Avatar
what is specail about that head. im a total newb to toyotas.
Old Dec 18, 2006 | 05:52 AM
RTon20s's Avatar
The other option, which no one has tried is the 1NZ-FXE (Prius) bottom end with our stock head. You would have to run either piggy back or stand alone engine management though.
Big compression bump, and no actually knows if it will work yet or not. If someone could get it to work physically, and get it tuned right I have no doubt they would have the quickest N/A xB in the country. (Especially now that Tony added a turbo to his car.)
Old Dec 19, 2006 | 02:39 AM
Xblozv's Avatar
what kind of numbers do you think that would make??
Old Dec 19, 2006 | 07:47 AM
RTon20s's Avatar
If it physically worked, and you got a good tune I would conservatively estimate it at 135+ hp to the wheels.
Old Dec 19, 2006 | 08:06 AM
hotbox05's Avatar
a zz motor swap if you know a shop should be around 5k motor , trans , ecu fab and install.
add the trd supercharger and you have 162 or 163 whp stock motor. so about 180 crank. add bolt ons and you've got about 180 wheels. with a warranty that the s/c wont blow the motor. and you'll be very , very fast.
Old Dec 21, 2006 | 06:40 AM
Scorpius01's Avatar
There are Factory turbo 1NZ-Fe in existence, 5PSI same 10.5 compression, 140hp. Available in some parts of europe and Some Asian countries.
Old Dec 22, 2006 | 03:03 AM
Xblozv's Avatar
so is that a motor swap or a head swap. not trying to be an ___ just wasnt sure what you ment by that?? thanks for the inf othough.
Old Dec 23, 2006 | 04:39 AM
Scorpius01's Avatar
It is a motor that you could directly swap in, with some wiring involved, but sourcing one can be tricky.
Old Dec 23, 2006 | 10:50 AM
hotbox05's Avatar
sourcing 1zz and 2zz complete(motor , trans , ecu) is easy as almost all toyota specific wrecking yards will most likely have it on hand.
Old Dec 23, 2006 | 11:12 PM
Xblozv's Avatar
ok.....sorry for this dumb question but
1zz=corrola
2zz=celica gts
right
Old Dec 24, 2006 | 06:28 AM
hotbox05's Avatar
2zz is in celica gts , corolla xrs , matrix xrs , and in a modified form is in the lotus elise.
Old Dec 24, 2006 | 03:14 PM
Xblozv's Avatar
was i right on the 1zz??
Old Jan 31, 2007 | 12:05 AM
if you want to do a head swap, try the zpi head, its only 550 with your head and thats dirt cheap for a port and polish.
Old Jan 31, 2007 | 06:56 AM
RTon20s's Avatar
With probably no gain in power. Unless you are boosted you most likely will not see a gain in horsepower.
Though your car may be quicker. You will be hauling less weight with the $550 ZPI got out of you.
