CEL just appeared
Old Dec 18, 2006 | 06:44 PM
Sniffs's Avatar
Default CEL just appeared
I'm a few hundred miles away from my 15k miles.. my bro said that the reason the CEL is on is because of the 15k "maintenance" limit and I shouldnt have anything to worry about.. is this true? I have a CAI, but it's been on for almost 10k miles...
I've checked all the fluids, and I've been to all my scheduled maintenance and my next one is in 4k miles.. is the CEL most likely just the 15k mile maintenance????
Old Dec 18, 2006 | 07:05 PM
SquallLHeart's Avatar
nope.. CEL won't come on because of that.
there must be another issue. try resetting the ecu?
you shouldn't drive with that light on.
Old Dec 18, 2006 | 07:14 PM
Sniffs's Avatar
What could it possibly be?! I mean ____ its been driving great.. I maintain all the fluids, all the tire pressure.. it just appeared on, on Sat morning..
If I take it to toyota, they should be able to hookup their computers and determine what it is correct?
Old Dec 18, 2006 | 07:17 PM
yup.. or any place.. i think places like autozone can check the code for you for free
Old Dec 18, 2006 | 07:59 PM
Sniffs's Avatar
I just went to Toyota.. they said 95 dollars to check it!! WTF??!?!?
I asked the guy about how long it takes and he said about 4 hours.. I then said "It takes 4 hours to hookup a machine to read what the CEL means?" and he said no that it was busy, and that I should just come back tomorrow!! ?!
If my engine gets ruined.. I'm taking it to toyota and quoting that guy..
He said "Well it is running wierd?" I said "No.. its running absolutely normal.. I even checked all the fluids, tires, brakes etc.. nothing appears out of the ordinary" and thats when he said "well it's pretty busy.. you should come back tomorrow.. .I doubt the CEL is anything to worry about"
Old Dec 18, 2006 | 08:28 PM
you can always try to get rid of it by resetting the ecu.. (disconnect battery for a few minutes)
if it comes back, then.. then yes.. you have a problem..
Old Dec 18, 2006 | 08:31 PM
KINGxOFxSKA's Avatar
Unique Scionikz
doesn't the check engine light come on for oil change maintainace.... or is that a diff light?
Old Dec 18, 2006 | 08:35 PM
that's the "maint req'd light"
that's just really mileage counter. ohh.. you've driven so and so miles after last reset? ok.. time to blinky!
Old Dec 18, 2006 | 09:08 PM
Sniffs's Avatar
Would the CEL come on if the fuse box cover wasnt on? I went to Vertexracing last weekend and forgot my fusebox cover..
Old Dec 18, 2006 | 09:10 PM
uhm.. no...
not unless a fuse or a couple got blown
some fuses go byebye can cause a cel.
djct_watt's Avatar
Team Sushi
Try checking the gas cap. . . a loose gas cap will set off the CEL
Old Dec 18, 2006 | 09:11 PM
^^ oh yea.... forgot about that..
the countless people i've seen that have done that...
oyy.... "TURN UNTIL IT CLICKS!"
Old Dec 18, 2006 | 11:04 PM
Sniffs's Avatar
I checked that.. I WISH it was the gas cap.. *sigh*
Old Dec 19, 2006 | 12:37 AM
djct_watt's Avatar
Team Sushi
It's too hard to troubleshoot the car and not be in front of it. Get the code checked and see what happens. For all I know, it was a tank of bad gas.
But from what I've seen and using the rule of generalizations, it's probably an over oiled or poorly filtering CAI filter that fouled that MAF. But it's a pretty big generalization, since anything can set off a CEL.
Old Dec 19, 2006 | 03:09 PM
Sniffs's Avatar
Well friday night it was driving fine.. no CEL.. I turn it on Sat morning and thats when I first noticed it..
The only thing I've done to it since then, was take off my front bumper, take off both my headlights to caulk them, in the process I biffed up a fuse ,so I took off my fuse box and and changed the fuse.. in the process of putting on my headlights and bumper, I forgot to put the fusebox cover back on.. so I'm currently driving around without a cover (I need to go back to where I was working on my car.. but its pretty far)...
Old Dec 20, 2006 | 12:48 AM
Sniffs's Avatar
I took it to Autozone and they ran the check for free.. It said P0441 and P0445 and it said something about EVAP and Emission Control something or other...
EDIT: it said this for the 441 "P0441 evaporative emission control system incorrect purge flow" the 445 said something else tho
EDIT: I just read up on the 445, supposodly the valve has short circuited..
"P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted"
does toyota warranty against this? cars a year and a month old with 14,800 miles...
Old Dec 21, 2006 | 04:00 PM
fugeelama's Avatar
You're under 36k miles; I think the warranty covers just about anything that happens to the car that isn't the fault of you 1) driving it into a tree or 2) putting some sort of mods on yourself.
I'd take it to Toyota and have them check it. There shouldn't be any charge for running a CEL diagnostic on a car that's under warranty, but fixing it is a different story... oh and you might want to take your CAI off before you go if it's something you put on after you got the car :>
Old Dec 21, 2006 | 04:09 PM
Sniffs's Avatar
it is something I put on the car after, I even told the dude at Toyota that I had a CAI and he said dont worry about that.. they work on cars with them all the time..
I'm taking it to toyota tomorrow and telling them what the CEL is about and that I have a CAI and see what they say..
I have the AEM intake which is exactly like the TRD (which they warranty against), and AEM makes the TRD intake.. plus.. dont they have to first determine that it was the intake that caused the issue?
Old Dec 26, 2006 | 03:52 PM
Sniffs's Avatar
Wierdest thing.. I go to turn on my car last friday because I had the day off and was going to go take it to Toyota.. well I turn it on.. and BOOM.. NO CEL??.. how can this be? can things correct themselves?? is my sensor broken? car still drives perfectly normal..
Old Dec 26, 2006 | 04:01 PM
spECIal's Avatar
it was prolly something u put on, then the CEL needed time to adjust then cut itself off.
well........maybe.
example.
i had an sentra se-r and put a aem CAI on it. my CEL was on for a couple of days then turned off
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
ScionLife Editor
Sep 29, 2015 12:30 PM
ScionLife Editor
Sep 24, 2015 10:50 PM
ScionLife Editor
Sep 16, 2015 10:00 PM
