question
Old Dec 26, 2006 | 05:15 PM
ayS's Avatar
ayS
Default question
i've had balancing problems when i had my new wheels installed and had to go back and get them rebalanced. since then they have been great. then the other day i drive about 80 and noticed my stering wheel start to shake? is this normal? i have sport max 002's. i wonder if anyone else is experienceing the samething or is it just another bad balancing on the wheels and tires?
Old Dec 26, 2006 | 05:23 PM
web's Avatar
web
If the wheels keep going out of balance, you could have a bad set. The belts maybe be shifted in the rubber material. If they are reletively new, I would contact the vendor or manufacturer and let them know about it and how you've had to balance them 2 times already.
Did you get an alignment done also? If you don't get the alignment done with new tires and they are already problematic, you may think it's just the tires. Then after you balance the tires, you notice it's slowly coming back. Have your suspension checked to make sure your tie rod ends are properly adjusted and tightened.
Old Dec 26, 2006 | 09:06 PM
jmseals's Avatar
jack your box up & check out your tires, mine started doing that with wear, lots of shake from 65 ta 75 MPH .
Old Dec 31, 2006 | 04:03 AM
ong's Avatar
ong
guys ....if possible you guys try the balancing on car.....that will help alot....but it cost alot of money todo balancing on car (they don't offer lifetime balancing, just on time and its about $.15 per tire)....hope that helps.....
Old Dec 31, 2006 | 04:56 AM
Tomas's Avatar
Admin Emeritus
Quick question: Since you are using aftermarket wheels, are you sure you have the right size centering rings installed in them? The Scions are designed to be hubcentric mounts, and if you use just the lugs to center the wheels, they will eventually shift and cause just that sort of problem...
Tom
Old Dec 31, 2006 | 01:22 PM
imboxtin's Avatar
CinSity Scions
SHOULDN'T THE VENDOR KNOW THIS BEFORE THEY SELL?
Old Dec 31, 2006 | 02:59 PM
stew32's Avatar
Default Re: question
Do you only get the shake around 80? My xB will also get a little shake in the steering wheel at 80. I drop a couple miles per hour and it goes away. It's not something you can feel in the car, just a slight vibration coming through the steering wheel. Most likely a tire slightly out of balance, but I almost never drive that fast so it doesn't bother me much. Hopefully it will go away the next time I rotate the tires.
Old Dec 31, 2006 | 07:05 PM
Tomas's Avatar
Admin Emeritus
Depends - if the vendor is some other guy with a car, it might be doubtful. If the vendor is a dealer that sells wheels for many different cars and doesn't even know what kind this is going on, no. Even if the vendor knows centering rings should be used, that's still the responsibility of the person mounting the wheel on the car. Many places sell their aftermarket wheels without rings, or with rings as an item to be added.
All I'm doing is asking if the wheels have the correct size rings, since that can cause this sort of problem.
Tom
Old Dec 31, 2006 | 07:18 PM
tanakasan's Avatar
Tom
Yes, must...have...rings...for xB.
My box is stable at 80+. Get the phenolic (plastic) rings, not the metal ones. You *can* mount w/o rings, but as Tomas stated, you will eventually have the exact problem you described.
Old Dec 31, 2006 | 09:12 PM
imboxtin's Avatar
CinSity Scions
Yes this is good the more we talk about our cars the more will learn all the time fantastic!
imboxtin's Avatar
CinSity Scions
Old Jan 6, 2007 | 12:26 AM
jizzypickle's Avatar
where can you get these "rings"
Old Jan 6, 2007 | 12:52 AM
tanakasan's Avatar
Mine came from:
http://cgi.ebay.com/ebaymotors/SCION...70273135QQrdZ1
No problems, fast delivery.
These are from the same seller, but I cannot remember if this is the CORRECT size!
Double check the size!! It must match the specific wheel ID and your hub OD.
Old Jan 6, 2007 | 12:57 AM
cool, thanks MENG!!!
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
