What's up SL? I Want Lights Under My Tires So Bad!!!! Help!!
Old Jan 3, 2007 | 03:13 PM
NeverBePeace's Avatar
Default What's up SL? I Want Lights Under My Tires So Bad!!!! Help!!
I bought my box in oct. Its still stock. Since I'm in school, I have no money nor time to fix up my box. However, I've been wanting blue lights under my wheels....well on top of my wheels. Keep in mind that I don't have much qwap($) to work with. What is needed to make this happen? In my last car, I had lights inside under the dash board of the driver and passenger side. Are the same lights used for putting lighting on top of the tires to? Not looking to installing myself either. How much am I looking at for this project? Any advice would be appreciated. Thanks
Old Jan 3, 2007 | 03:16 PM
CXT's Avatar
CXT
if you just want lights on top of your tires 4 led strips fom oznium.com, some red and black wires and a switch.
Old Jan 3, 2007 | 04:14 PM
Yea just lights.......can I get the lighting from pep boys? And just have some dudes from my local spot hook it up?
Old Jan 3, 2007 | 04:16 PM
ROBs-xB's Avatar
Just go to Oznium.com they have everything, and you could do the installation
yourself, it should be pretty easy, no need to pay for labor if you can do it yourself
Old Jan 3, 2007 | 04:23 PM
cherryBox's Avatar
the only marginally difficult part of the install is passing thru the firewall - i imagine you'd get raked over the coals if you asked a shop to install it.
they'd spend at least two hours laughing about it, and charge you for it.
a) find a place to tap for power (check the cold cathode install in the tech section)
b) wire to a switch, use the gardner-bender GSW-45 or hit up a guy named 'couped' on here
c) run the wires thru the firewall (driver's side behind dash above the clutch)
d) run the wires to all four wheelwells (make sure you do it so they can't flap around!)
Old Jan 3, 2007 | 04:25 PM
Rabid_Lemming's Avatar
Ask other Scion tuners in your area for help. Most people on here don't mind lending a hand, plus you learn more about your ride =) Bear in mind, you're asking for help, not a free install.
Old Jan 3, 2007 | 04:39 PM
Can I just go to a pep boys or autozone to purchase the lights? I really have no time to order online and then wait. What demention is a good fit for putting it on top of the tires?
Old Jan 3, 2007 | 05:56 PM
cherryBox's Avatar
if you want to spend way more than you should, by all mean, go to pepboys. from your original post, it sounded lke you wanted to keep the cost down. Impatience is always expensive.
use your best judgment on the size. they may work, they may not. who knows.
(the real answer to your question is contained in the replies above)
Old Jan 3, 2007 | 07:28 PM
EZ-BAKED's Avatar
I orderd 12in cathode and hade them the in 2 days it mite have been 1day. from Oznium.com great stuff for how cheap they are. And do it yourself way to ez
Old Jan 4, 2007 | 01:02 AM
zinker's Avatar
www.oznium.com has super fast shipping and low prices.
and if use used neon or cathodes in your wheel well they'd break after a few rock hit em
Old Jan 4, 2007 | 01:33 AM
TerribleTed's Avatar
www.oznium.com ships extremely fast never more than 3 days tops. Their stuff is top quality and cheap also. check them out. Much better to wait than Pep Boys in this case.
Old Jan 4, 2007 | 01:58 AM
badbasic's Avatar
www.oznium.com rules! i have ordered several times and so far havent waited longer than 3 days. much cheaper than going to a parts store.
Old Jan 4, 2007 | 02:47 AM
CXT's Avatar
CXT
Oznium.com is having a sale on led strips.
and in case you didn't read it the first 15 times....Oznium.com
Old Jan 4, 2007 | 03:14 AM
cherryBox's Avatar
good job guys!
Old Jan 4, 2007 | 08:18 AM
Mr_Purple's Avatar
What's oznium??
Old Jan 4, 2007 | 12:51 PM
CXT's Avatar
CXT
^^^Ban!!!^^^ lol
xBSciontist
Jun 18, 2019 03:06 PM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
TheTripleC
Jan 4, 2015 06:46 PM
minter66
Dec 15, 2014 01:45 PM
