Front Sidemarkers on xB....
Old Jan 4, 2007 | 11:41 PM
jgonzalvo's Avatar
Default Front Sidemarkers on xB....
I want to replace these with clear ones.....I don't think I've seen any posts on this, but how do you remove the OEM ones? are they pressure fit? all the posts I've seen are for the rear sidemarkers.....
Old Jan 4, 2007 | 11:45 PM
SquallLHeart's Avatar
hmm.. just use your fingers and pry them off.
Old Jan 5, 2007 | 03:56 AM
TerribleTed's Avatar
Actually the safest way to remove them is to loosen the splash skirt just forward of the light so you can get your hand inside. One end of the lamp is a tab that pokes in under the sheet metal of the fender the other is a springy tab that latches the lamp to the fender (the forward end is this as I recall). Simply push toward the light on the springy end and it pops right out. Safer because if the spring tab end is a bit tight it may not want to come loose, simply pulling could possible damage the fender or the lamp.
Old Jan 5, 2007 | 12:35 PM
jgonzalvo's Avatar
Thanks for the tip....I didn't want to just pry them off....
Old Jan 6, 2007 | 08:43 PM
loserjohnny's Avatar
i just pushed them to the side towards the hood til they popped off, took a bit of work
Old Jan 8, 2007 | 02:11 PM
HeathenBrewing's Avatar
Doesnt anyone read the Owners Manual anymore?
It tells you how to take them off.
Old Jan 8, 2007 | 02:19 PM
cherryBox's Avatar
yelp. rtfm
pdxgen2
Scion xB 2nd-Gen Wheel & Tire
Mar 14, 2015 01:56 AM
umnitza
Dec 1, 2014 06:26 PM
yanges
21
Dec 16, 2003 10:25 PM
