rubbing questions for wheel experts
Old Jan 10, 2007 | 04:05 AM
vekthurr's Avatar
Default rubbing questions for wheel experts
Im thinking about getting new rims with a staggered fitment for my bsp. Would 18x8.5 (front), 18x9.5 (rear) fit on a tC? I have a 1.5" drop on my car. would there be rubbing issues? And what size tires would fit on those rims?
Old Jan 15, 2007 | 07:25 AM
captainlaziness's Avatar
Offsets?
Old Jan 16, 2007 | 12:18 AM
vekthurr's Avatar
these are the wheels. 38mm offset
Old Jan 19, 2007 | 05:55 PM
pdjray's Avatar
I am planing to get the Tork revo's staggered http://www.wheelnext.com/default.cfm...lor=HYPERBLACK
18x8 in front and 18x9 in the rear. 5x100 bolt pattern on 225/35/18 tires in the front and the rear. Is this a good idea? Will it work? I also want to know other peoples thoughts about it. I am on tien s techs. So iam a bit affraid i will rub all the time.
Old Jan 19, 2007 | 06:45 PM
Neothin's Avatar
they'll fit... but your going to get some hellacious rubbing. fender rolling and probably the removal of the fenderliner will probably be needed.
that's just what i found comparing the size/offset to my own wheels. the clearances are going o be tight.
Old Jan 19, 2007 | 09:19 PM
pdjray's Avatar
hmmm is rolling your fenders bad? Can i roll them back to stock . Neothin are you rubbing with ur rims and tires. Any rolling of the fenders?
Old Jan 20, 2007 | 12:32 AM
nebster's Avatar
its only bad if you screw it up and don't take your time. that is a perminant modification and cannot be undone so be careful if you choose to do it. my call would be just not dot the gigantic wheels.
Old Jan 20, 2007 | 04:28 AM
His wheels aren't as extreme as the ones you want to run. 18x7.5 +48mm offset enkei RP02`s, 225/40/18 Falken Azeni ST115`
Old Jan 25, 2007 | 06:21 AM
stCx86's Avatar
Default rubbing issues.
hey maybe u guys can help me out..i just put my wheels on 18x7.5 with a 42 offset. running 225/40/18 and every one said they wouldn't rub but i do!! nothin serious but it seems like it's coming from the rear on my side...i don't know why it never rubs on the passenger side...when i go over small bumps or while driving and hit uneven pavement..the wheel will rub. it ALWAYS rubs when i make right turns. does any one know why?? i had both rear fenders rolled and STILL rubbing...help me fix this pleasE!!!
Old Jan 25, 2007 | 06:23 AM
Is your fender liner in the correct place?
Old Jan 25, 2007 | 07:20 AM
stCx86's Avatar
yah everything seems to be in place....i don't know if this is a stupid question. but am i suppose to go get my lug nuts re-torqued after putting on new wheels? or an alignment re-done?? I just had the wheels for about a day now but i wasn't sure....if that could be a cause...please advise..thanks in advance!
Old Jan 25, 2007 | 07:25 AM
Yes, you deffinately want to make sure your lug nuts are torqued down. An alignment isn't necessary.
Old Jan 25, 2007 | 07:30 AM
Chapman's Avatar
Quick question, is there a downside to removing your fenderliner?
Old Jan 25, 2007 | 07:33 AM
It looks weird?
stCx86's Avatar
do u think that not re torqing my lug nuts after my wheels were put on could be the problem??
Old Jan 25, 2007 | 07:35 AM
I dunno...maybe.
But if your lug nuts aren't torqued down all the way you may have bigger concerns.
Old Jan 25, 2007 | 07:36 AM
stCx86's Avatar
Default rubbing issues...
ok kool..thanks for the feedback...any other suggestions on why I could be rubbing in the rear...and only on my side. well atleast it sounds like it's coming from the rear...i could be wrong....
Old Jan 28, 2007 | 01:19 AM
05FMtC's Avatar
i think he has spacers.
Old Jan 28, 2007 | 01:22 AM
nebster's Avatar
yep he's got 15mm spacers bringing his to +33
bbsciontc
Scion tC 1G Wheel & Tire
Aug 19, 2019 01:46 AM
meowtc
Mar 5, 2015 02:28 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
IrjI619
Jan 28, 2015 05:21 AM
Beesh
Jan 9, 2015 06:30 PM
