Irregular dipstick reading need advice
Old Jan 11, 2007 | 03:54 PM
Andrew1782's Avatar
Default Irregular dipstick reading need advice
Ok you guys this actually has to do with my Tacoma.
When I check the oil one side of the dipstick looks WAY high, but the other side is just at the right level. Why am I getting 2 different readings on my dipstick and which one should I follow?
And yes the vehicle is parked on level ground etc etc.
Thanks everyone.
Old Jan 11, 2007 | 04:01 PM
jct's Avatar
jct
sounds like the dip stick is going at an angle to the oil pan go with the side thats is at the correct fluid level
Old Jan 11, 2007 | 04:02 PM
tCizzler's Avatar
my moms truck does that too... S10. But her oil fill and dipstick are in the same hole. so oil running down the tube sticks to the sidewall of the tube. Possibly the same in your case. even if the fill and dipstick are in different places, driving can cause the oil to move around and stick to things.
Just a possibilty
Old Jan 11, 2007 | 04:04 PM
Andrew1782's Avatar
So you think I should read the lower side? I just didn't want to end up blowing something up because the level was too high.
Old Jan 11, 2007 | 04:18 PM
jct's Avatar
jct
it will be fine, if your worried about it give it an oil change with the correct amount of quarts of oil
Old Jan 11, 2007 | 05:27 PM
HeathenBrewing's Avatar
Check your oil after it sits overnight. That will give all the oil a chance to drain off the dipstick tube.
Old Jan 11, 2007 | 05:28 PM
cherryBox's Avatar
that's great advice. do the oil change, check the levels on the stick, and us that as your future baseline.
06ScionTc5sp1
9
Oct 16, 2020 01:18 AM
DougC
Feb 22, 2015 02:39 PM
Miqmiqmiq
Feb 4, 2015 05:05 PM
StatuSCheckA
Scion tC 2G ICE & Interior
Dec 4, 2014 03:15 PM
gularti
Dec 4, 2014 01:21 PM
