our block has cast sleeves????
Old Jan 13, 2007 | 03:30 AM
8psiXA's Avatar
Default our block has cast sleeves????
i read that our block already has cast sleeves stock?? so with a piston rod combo they would be pretty much bulletproof right? how thick are the stock sleeves? is this even true??
also anyone with pictures or something that would be cool.. thanks
Old Jan 13, 2007 | 09:00 AM
metal112524's Avatar
ya its sleeved (is that how you spell sleeved???) RPi put out pistons at 9,5:1. He says we can see bout 30psi with rods and pistons.
Old Jan 14, 2007 | 02:27 AM
8psiXA's Avatar
well i feel stupid now.. all aluminum blocks do.. im used to cast iron "closed deck" blocks... but ours is aluminum block "open" deck with cast sleeves..
Old Jan 14, 2007 | 08:46 AM
if you say so.
Old Jan 15, 2007 | 07:29 PM
autopainter13's Avatar
the walls arent even thick enough to bore it out any. we had mine sonic tested. there is the minimum amount of material there.
Old Jan 15, 2007 | 11:23 PM
8psiXA's Avatar
delete me lol
Old Jan 15, 2007 | 11:24 PM
8psiXA's Avatar
well i know 12 psi has been done by zpi.. so ill just stick with 8-10 to be safe
Old Feb 15, 2007 | 07:53 PM
Guest
Guest
Posts: n/a
Similar to a tC block...it's an aluminum block with open deck and "paper-thin" sleeves. You can add rods and pistons, but the weakness is the block. So many on this forum have claimed to run their turbo setup on their xB up to 12+ psi producing 170-200+ whp....not sure how this is doable on a stock block.
All the turbo kits currently available for this motor is capable of producing more HP than the stock motor can handle.
Old Feb 16, 2007 | 07:43 PM
Simplyscion's Avatar
Team No Limitz
I was actually able to run 13 psi on multiple passes on my auto xB with a T20BB and a return line fuel setup. I didnt get to dyno it at 13 psi so I have no idea what kind of numbers it was putting down...I did get dyno'd at 6 psi and the car put down 123whp...Id assume @ 13 psi it had to put down around 150whp
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
SloTC1
Aug 16, 2018 02:45 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
TheGovernmenT
Sep 4, 2015 11:57 AM
