Noise in front strut...only 18xxx miles
Old Jan 13, 2007 | 02:06 PM
JoeBus's Avatar
Default Noise in front strut...only 18xxx miles
So I put H-Techs on my car about 9xxx miles ago and just last night i hit a bump and heard a slapping noise and it now makes that noise everytime I hit a bump. It is the same noise that my camry had when it had about 140xxx miles on it. Did i botch the install? It does not ride any differently at all it is just the noise that worries me. Any help would be awesome!
Old Jan 13, 2007 | 03:00 PM
ROBs-xB's Avatar
Possibly your CV BOOT clamp came off, so the boots loose
and needs to be replaced
Old Jan 13, 2007 | 04:14 PM
xA_Factor's Avatar
One possibility:
The top spring perches on the front struts fit over a keyed portion of the damper rod. If it's not seated right, the rod will wallow out the hole in the spring perch and become loose over time. You usually get a knocking sound once this happens.
Old Jan 13, 2007 | 05:05 PM
JoeBus's Avatar
I thought i lined everything up right when i was doing the install...i will check once it stops raining.
Old Jan 14, 2007 | 01:27 PM
BrianxB's Avatar
Originally Posted by xA_Factor
One possibility:
this is the problem.
Old Jan 14, 2007 | 02:24 PM
JoeBus's Avatar
fun...well i am still waiting for my lug nut key to get here (the stupid thing broke) then it will be fixen time. is it bad to drive the car right now?
Old Jan 16, 2007 | 06:39 AM
bB2NER's Avatar
Music City Scions
Just re-tighten the upper center nut under the rubber cap on the top of the strut. Sometimes this nut doesn't get seated right and needs to be retightened shortly after doing a spring install. It happened to me once and it freaked me out but retightened it and took care of the noise.
Old Jan 16, 2007 | 01:30 PM
JoeBus's Avatar
I will give it a shot...but it has been 9,xxx miles since the install.
Old Jan 16, 2007 | 07:33 PM
JoeBus's Avatar
Man i love this place!!!! thanks ^^^^^^^^^^^ just one bolt that worked lose and all that noise is gone.
Old Jan 16, 2007 | 09:29 PM
xA_Factor's Avatar
You'll want to keep an eye on things, because it could still be the top perch that was mentioned above. The top nut can loosen over time has the perch wears if it was not seated properly on the damper rod.
Old Jan 17, 2007 | 12:05 AM
bB2NER's Avatar
Music City Scions
No problem Bro! Stick with us and we won't steer ya wrong!
Old Jul 19, 2007 | 05:04 PM
rygar's Avatar
I had the same problem this week. I tightened the center strut bolt and problem solved. I want to either replace the nut with a nylon lock nut or add a second nut on top to act as a lock nut. Does anyone know the size and thread pitch of the nut? Yeah, I can take it off and go to the store but I'd rather not.
Old Jul 19, 2007 | 10:02 PM
bB2NER's Avatar
Music City Scions
Adding the second nut did it for me. Don't have the size tho cause I already had em from a different strut job I did.
DaBlackBox
134
Apr 10, 2022 02:04 PM
scotttie17522
Feb 23, 2020 08:38 AM
meowtc
Mar 5, 2015 02:28 AM
minter66
Dec 15, 2014 01:45 PM
TwisTeD_ScioN
10
Sep 22, 2004 09:32 PM
