K Sport Coilover Owners PLEASE READ
Old Jan 23, 2007 | 12:59 AM
DTRUONG_112's Avatar
Default K Sport Coilover Owners PLEASE READ
So I installed my coilvers the other day, the fronts are slammed and love the look, but the probelm, my rear still has a four finger gap. On the KSport site it says to adjust height, required to adjust the lower mount, which I did on the rears, to lower they said you have to spin the lower mount up, I moved the lower mount all the way up to the point where it cant spin anymore and adjust the spring perch all the way down and still have major wheel gap, anybody with their input help me out?
Old Jan 23, 2007 | 03:08 AM
anybody?
Old Jan 23, 2007 | 04:02 AM
Merc_tc's Avatar
mine was the same way. just let the springs settle.
Old Jan 23, 2007 | 05:10 AM
hotbox05's Avatar
you spin it down to the bottom.
i have about a 1 finger / three fourths finger gap with it all the way down with both adjusters still on.
i guess i can take pictures tomorrow if you guys need em.
Old Jan 23, 2007 | 02:40 PM
on the xbs it might be different, cause on the site, it the coilovers come with the lower mounts like the tC, the lower mount is used to lower/raise the ride height, spinning it down would raise the height and and spinning it up would lower the ride height. Im hoping its because its just a new spring.
Old Jan 23, 2007 | 05:34 PM
yamaha16bw's Avatar
Pics?
Its got a threaded Shock body correct? If so I would think its like my brother Tein's in that you have to thread them down in order to lower the car. Of course these could be different
Old Jan 23, 2007 | 05:39 PM
Merc_tc's Avatar
just checked mine. i can only get part of a finger in. just give it time.
Old Jan 23, 2007 | 05:41 PM
TtownXB's Avatar
i have ksport on my xb, and they have a 1 finger gap all around,
Old Jan 23, 2007 | 06:17 PM
2redgerm6's Avatar
make sure you snug the lower spring perch up till it is nice and tight against the spring. then put the height adjusting perch up as high as you can, till it is as close to the lower spring perch as possible.
Old Jan 23, 2007 | 06:49 PM
I did that, the lower mount is touching the spring perch yet I still have a major gap. Does the spring need to settle? Most coilover setups Ive seen when you first install it, no settling was required. Major wheel gap is ____ing me off, front is slammed but the rear is so high, looks like a funny car
Old Jan 24, 2007 | 06:02 PM
2redgerm6's Avatar
i seriously mean to tighten the rears up. make sure you can't wiggle the rear spring at all. then bring the lower height adjuster perch up to that. if that doesn't help i don't know what to say.
Old Jan 24, 2007 | 10:53 PM
Did that man, lower mount is spun all the way to the poing where it cant go any further up.
Old Jan 27, 2007 | 09:40 PM
jay_jay_n's Avatar
you may need a spring compressor to compress the spring so you can spin move the perch higher.. i will be doing this today i'll let u kno how it goes.
Old Jan 27, 2007 | 11:59 PM
let me know how it goes, did you run into the same situation? I have a spring compressor but didnt think that would be required.
Old Jan 28, 2007 | 05:28 AM
mahalzkita28's Avatar
on my tiens you need to make the spring closer to the bottom to make the ride height lower.
Old Jan 28, 2007 | 04:08 PM
yeah the teins and ksports are different, tein are adjustable perches while ksports are adjustable mounts
Old Jan 29, 2007 | 04:49 AM
jay_jay_n's Avatar
DAYM MAN.... i made the mount all the way up and i couldn't get it any lower.. it seems the only other way i can think of is to compress the spring more.. but the spring needs a really thin spring compressor to do it... i was thinking maybe if you do it the other way and loosen the springs mount that might lower it.. i don't have time to try it yet.. but i think that might be the solution.
i'll get pics up of what i'm talking about so other people can see but i think u'll get the idea.
Old Jan 29, 2007 | 02:52 PM
im in the same position man, They say it might just need to settle.
Old Jan 29, 2007 | 03:09 PM
Merc_tc's Avatar
it does i will take pictures of mine today
Old Jan 29, 2007 | 04:45 PM
jay_jay_n's Avatar
pls do merc.. here are pics of what we mean
this is my front drop and i'm rubbing right now and i kno i have to raise it a bit but i really was hoping i could tuck it in.
and here is the rear drop, as u can see the drop isn't as low as the front and the back is 2 finger gap compared to no finger gap in the front, my s-techs in the rear would make the rear tuck in, i've actually debated about putting my s-techs back in the rear so i can get the drop i want lol..
and this is the problem, the bottom of the shock mount is turned up all the way and can't go any higher meaning it can't go any lower, so i tried my hardest to turn the springs perch up and it lowered it very minimally, so i assume that i was doing it wrong and it should actually be turned down so the spring isn't pushing up the top mount up and instead letting it drop so it would lower the car.. am i correct?
