Suspension???
Old Jan 24, 2007 | 11:34 PM
Gio07tc's Avatar
Default Suspension???
What kind of sospention should i put on my Tc? I was thinking Trd struts with hotchkis springs or trd struts with trd springs? what do you guys think?
Old Jan 24, 2007 | 11:43 PM
sddykstr's Avatar
Sounds good. Question though, how did you spell it right on the title and not in the body.. lol. Honestly though, if you're spending the money on struts and springs, why not go with coilovers, it won't be that much more.
Old Jan 24, 2007 | 11:55 PM
Spect2K3's Avatar
coilovers are much more expensive. if you won't utilize the benefits that they offer, its not worth it. I'm a fan of the trd setup. I have the trd spring (not shocks, i didn't think the cost to value ratio was worth it, so i'm on stock shocks).
If you do go with the hotchkis springs, then you may need to invest in trd struts as that is more of a drop than the stock shocks are supposed to handle. They will work, but die too prematurely that its worth compressing the springs just once rather than twice to put the springs on new shocks when they blow.
Old Jan 25, 2007 | 12:11 AM
Gio07tc's Avatar
how does the car run with only Trd springs?
Old Jan 25, 2007 | 12:14 AM
Spect2K3's Avatar
I can't tell a difference between trd springs with trd shock and trd springs without trd shocks. They will hold up longer than using the stock shocks b/c any lowering spring (big or small drop) will put extra strain on the shocks. So if the difference is so little that its barely even noticable, i'm not gonna waste all of that money (shocks are expensive). When the stock ones blow, i'll consider getting the trds then. I've read that the trd shocks are a little shorter and have more nitrogen in them - those are the only differences. Hope that helps
Old Jan 25, 2007 | 12:26 AM
Gio07tc's Avatar
ill probably save some money and go with Trd shoks and springs... i dont want a big drop cuz im planning on getting the visage jp body kit...
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
SloTC1
Aug 16, 2018 02:45 PM
prescottn
Sep 22, 2015 01:30 PM
Subaru86
Sep 14, 2015 12:51 PM
prescottn
Sep 13, 2015 09:04 PM
