CC short shifter bushings
Old Jan 26, 2007 | 05:45 PM
eliXion's Avatar
Default CC short shifter bushings
Hey everyone. i wanted to install my CC short shifter bushing thingys today. It comes with four of them. I just wanted to know how u put them in.
Old Jan 26, 2007 | 06:02 PM
BYeRhONe's Avatar
they just replace the stock shifter bushings. i didnt know what they were at first but once i found out it was self explanitory.
https://www.scionlife.com/forums/vie...ifter+bushings
13th picture hes pointing at 2 of the bushings
take them out, put the new ones in, wash rinse and repeat
Old Jan 26, 2007 | 06:56 PM
eliXion's Avatar
my package came with 4 but i only use 2?
Old Jan 26, 2007 | 06:59 PM
BYeRhONe's Avatar
the other 2 are on top
...like a square with 4 bases
Old Jan 26, 2007 | 07:00 PM
eliXion's Avatar
they look exactly the same though...thats right right?
Also, if i just install the 2 under the hood will that still be better, cause i installed my short shifter months ago and i dont feel like disecting it
Old Jan 26, 2007 | 07:04 PM
BYeRhONe's Avatar
i think the shortshifter bushings will be easier but sure. do the 2 under the hood.
Old Jan 26, 2007 | 07:08 PM
eliXion's Avatar
ill go give it a try..do u have AIM?
Old Jan 26, 2007 | 08:04 PM
Spect2K3's Avatar
The shifter cable bushings and the shifter base bushings are both VERY simple to do. Just make sure when doing the base bushings not to drop anything in the holes. You take out the bolt/nut and then remove the stock shifter base bushing. You then take the new ones and put one in on bottom and one on top, then tighten it down with the bolt/nut. You do this 4 times which means you need 8 bushings. 4 on top 4 on bottom. When you get in there, you will understand completely. This is easier than blowing your nose
Old Jan 26, 2007 | 09:44 PM
BYeRhONe's Avatar
cc shifter base bushings only have 4. and they are purpleish. im glad they dont show.
Old Jan 26, 2007 | 09:46 PM
Tcguy85's Avatar
4 on the top and 4 on the bottom?
Old Jan 27, 2007 | 02:11 AM
Spect2K3's Avatar
I have the corsport shifter base bushings...I should've mentioned. 4 bushings go underneath the shifter body (1 per corner) and 4 bushings go on top of the shifter body (1 per corner)
Old Jan 27, 2007 | 02:28 AM
Tcguy85's Avatar
alright, i have the creative compacts shifter so i have 4 bushings. the cool purple ones that thank god aren't seen cause i wouldn't want purple on my car.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
BlingSlade
Oct 19, 2016 12:39 AM
airmankevin1
Nov 17, 2015 05:44 AM
excessads
Sep 15, 2015 05:28 PM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
