Will this fit? [url]http://www.streetdreams.org[/url] said so.
Old Jan 29, 2007 | 09:54 PM
Italiangurl's Avatar
Default Will this fit? http://www.streetdreams.org said so.
i viewed this http://www.streetdreams.org and it said that Axis Hiro: 19x8.5
:: 5x100 :: 35mm offset :: Hyper Silver will fit..... will they?
can anyone give me the url of some website that are good and low price on rims and tires.??? i have the money for it and need to make sure i get the right size without rubbing... im going after 19 inches but need help!!!
Old Jan 29, 2007 | 10:03 PM
captainlaziness's Avatar
Have you, or do you plan on dropping the car?
Old Jan 29, 2007 | 10:07 PM
Dr_Isotope's Avatar
Even with a stretched ultra-low profile tire, that's gonna rub. You're adding 38mm of rim width, and losing 11mm of offset-- the new combo is gonna stick out almost 30mm more than the OEM combo.
READ THIS for further info.
Old Jan 29, 2007 | 10:11 PM
Related topics:
https://www.scionlife.com/forums/viewtopic.php?t=158915
https://www.scionlife.com/forums/viewtopic.php?t=156166
https://www.scionlife.com/forums/viewtopic.php?t=158821
Old Jan 29, 2007 | 10:12 PM
yes im planning on dropping it. why ask? can 19 incehs fit on TC? if so,, can you give me the offset and etc?
Old Jan 29, 2007 | 10:21 PM
Yes, 19" wheels fit...depending on how much it's been lowered, the width and the offset and the tire.
Wheel size.....Tire size...Drop
19x8.0x40 - 235/35 - TRD or Less
https://www.scionlife.com/forums/viewtopic.php?t=101733
Old Jan 29, 2007 | 10:31 PM
shadow12one's Avatar
If your on TRD springs you should possibly be fine. If you get a set of coilovers, i suppose you can adjust them until you get a good height.
Old Jan 29, 2007 | 11:27 PM
lil_will's Avatar
ScionERA
I am running 19x8 with a 42 offset - 215/35 - on H&R Sports
No rubbing at all.
Old Jan 29, 2007 | 11:30 PM
nebster's Avatar
yeah but he'll be running 12 less offset. so its gonna stick out 12 more mm. = LOTS OF RUBBING.
Old Jan 29, 2007 | 11:32 PM
Those H&R Sports springs have a drop similar to TRD's, that's why they work.
Beautiful wheels..car's not bad either. :D
Edit-
Also that the wheels are only 8" vs 8.5"
Old Jan 29, 2007 | 11:36 PM
Hyghgynx's Avatar
I hope SHE isn't a he! Stick with a +42 offset and TRD (or similar drop height) Springs and you should be golden.
Old Jan 29, 2007 | 11:41 PM
what you mean that i might be a "HE"?? got a bad past on that one?
Old Jan 29, 2007 | 11:45 PM
Ooooo Burn! :D
Old Jan 29, 2007 | 11:48 PM
tekmunny's Avatar
Yes...you will be fine depending upon your drop.
Im running 19x8.5 sterns with 225/35R19s on a TRD drop.
I've never rubbed with the conservative TRD lowering...however i'm never been happy with the TRD's because of the uneven-ness from passenger to driver side.
I have 1 inch gap on driver side and 2 inches on the passenger side...i've read many other TRD spring owners with the same problem.
I have h-tech springs in a box but have yet to install them...i think those will be fine also...we shall see.
Oh...i'm not posting pics because after seeing lil_will's black tC...i'm feeling a little inadequate. lol.
Old Jan 29, 2007 | 11:58 PM
Hyghgynx's Avatar
I was not implying that you were a "he". Re-read the posts. It wasn't me...
Xversa
Scion tC 2G ICE & Interior
Dec 30, 2014 04:37 AM
Opr8r
Oct 5, 2004 03:09 AM
LVXB
10
Mar 12, 2004 06:08 AM
LVXB
Feb 24, 2004 04:44 AM
