Header/ CEL Questions
Old Feb 1, 2007 | 03:48 PM
tcash78's Avatar
Default Header/ CEL Questions
I have a couple questions, has anyone found an exact fix for the CEL light coming on? I have tried all of these fixes that were listed on here and have had no success.
Would anything be accomplished if I replaced the S-pipe and remove the second cat?
Or has anyone tried moving the air/fuel sensor to the secondary O2S location and move the second O2S to a new location after the second cat?
The reason I ask is because the DTC that I was getting was saying there was a problem with the primary Air/ fuel sensor.
Thanks
Old Feb 1, 2007 | 05:07 PM
Scott8's Avatar
you may have damaged the o2 sensor when you took it out. I damaged mine and I was carefull as hell with it!
Old Feb 1, 2007 | 05:41 PM
HeirAutomotive's Avatar
I've heard putting Catalytic Converter Shaving in the AntiFouler will trick the sensor into thinking there is a Cat. Con. Installed.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
