engine rattles between 600-800rpms
Old Feb 16, 2007 | 07:15 AM
aznboy2lee's Avatar
Default engine rattles between 600-800rpms
Does anyone have the same problem? I recently noticed my engine rattles when idle, it shakes alot, the needle moving up and down between 600-800 rpm, I wonder what it could be
Old Feb 16, 2007 | 07:25 AM
InfideL's Avatar
i changed to synthetic oil and everything is smooth
how long since your last oil change?
Old Feb 16, 2007 | 02:18 PM
CuRiOuSfIsH's Avatar
is this when youre at 0MPH?
Old Feb 16, 2007 | 02:22 PM
mitchelltc1's Avatar
you're not driving (moving) at the time right? hmmm, I don't experience any of this, unless it's severely cold out and my needle drops suddenly, but even at that... I wouldn't call it rattling and definitely not shaking...
Do you have a manual? How's your oil? Did you just recently unplug the battery? Is it severely cold?
Old Feb 16, 2007 | 02:27 PM
Fsu1dolfan's Avatar
Does this happen when you start up the car after the battery is unplugged.....i had my front sway and NST pulleys installed and had my battery unplugged....later that night at idle i had it vibrate like it was gonna stall....but after a few times it went away and all is back to normal....kind of weird...why does it do that???
Old Feb 16, 2007 | 10:55 PM
Spect2K3's Avatar
I see you did an intake, header, etc. This could be due to a sensor malfunctioning. I'd check it out, possibly a trip to the dealer unless you have a buddy who can give you his sensor to try out. I could be wrong though...
Old Feb 17, 2007 | 02:27 AM
aznboy2lee's Avatar
I got a manual, I use synthetic oil on my every oil change, still about 1000 miles until the next oil change, the rattle shaking does when I am at idle, not moving, it suddently dropped about 100rpms, and it starts there, then I could feel the rattleing, it feels like when you give not enough gas when you accelerate.
Old Feb 17, 2007 | 02:29 AM
aznboy2lee's Avatar
what sensor? do u mean the o2 sensor?
Old Feb 17, 2007 | 02:33 AM
Spect2K3's Avatar
o2 possibly (there is an o2 sensor on the header)....but I was refering to the maf sensor. The maf sensor regulates lean/rich fuel-to-air mixture. The o2 sensor would throw a cel usually if there is a problem there (exhaust issue).
Another suggestion that came to mind - when you get a tune-up (which you should not yet need), the mech adjusts your idle....maybe you just need to have it regulated...
Old Feb 17, 2007 | 02:39 AM
Kumitsu's Avatar
This Happened to me as well.
alexxfender
Apr 1, 2015 03:06 PM
cid_mcdp
Jan 5, 2015 02:45 PM
StatuSCheckA
Scion tC 2G ICE & Interior
Dec 4, 2014 03:15 PM
Cameron
12
Feb 2, 2004 06:46 PM
jdtjunior
Jan 16, 2004 06:20 PM
