E-brake light on!!
Old Feb 19, 2007 | 12:14 AM
joxa's Avatar
Default E-brake light on!!
The other day I had my ebrake on in the cold and probably shouldn't have. Afterwards I was able to disengage it with no problem, but the light remains on. Is there a sensor or switch that could be stuck on? I am still able to apply the brake and take it off with no effect on the light... Any help would be most appreciated as to what the problem is. -Thanks
Old Feb 19, 2007 | 12:16 AM
bfurches's Avatar
check your brake fluid, it may simply be low or even have absorbed some moisture which will trigger the light.
Old Feb 19, 2007 | 01:59 AM
joxa's Avatar
I hadn't though of that. I was convinced that it was something frozen... I will look into that though, thanks. Is there anything else I should look at or check?
Old Feb 19, 2007 | 04:19 AM
TerribleTed's Avatar
The brake light is also triggered by a switch that actuates when you pull up the handle. Perhaps it is stuck. I have not looked at this myself yet . I would assume that it is located in the console at the rear of the ebrake ratchet, rather than somewhere along the ebrake cables.
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
carid
Jan 8, 2015 11:33 AM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
rolex87
Oct 2, 2003 04:31 AM
