my freakin sunroof wont close!!!
Old Mar 1, 2007 | 12:14 AM
hansta's Avatar
Default my freakin sunroof wont close!!!
i just had it open for like 5 min while havin a cig and when i tried to close it, it autimatically rolled back to where it was at. and i was like WTF!? (that's when the car was sittin still) and drove with it open and while driving, i tried to close it again and at that time, it closed........what the hell's wrong with my roof man!!!
can anyone help????
Old Mar 1, 2007 | 12:36 AM
falkor's Avatar
Could have been something in the ruts that caused it to go back and not close . Interesting as I have not heard of this until now on the TC . Does it now work while sitting still ? If still under warranty and is working ok , call the dealership so they know about it in case it quits working after the warranty period .
Old Mar 1, 2007 | 12:44 AM
hansta's Avatar
while sittin still it won't close on it self, i had to hold down the wind defelctor in the front of the roof down so that my sunroof can roll on top of that, while i'm drivin, i guess it's easier for the sun roof to close because wind actually pushes down the deflector, tha's my theory.... would that be covered under warranty
Old Mar 1, 2007 | 12:52 AM
KINGxOFxSKA's Avatar
Unique Scionikz
Clean your sunroof tracks!
Simple answer to a simple problem.
Old Mar 1, 2007 | 12:55 AM
falkor's Avatar
Cleaning the tracks is a must . If it still has a problem , yes , it is cvered under warranty .
Old Mar 1, 2007 | 12:57 AM
draxcaliber's Avatar
yeah, i had that problem long ago, the wind deflector wouldn't go down, i took it in under warrenty, they cleaned and greased the tracks and adjusted it or something. works fine now.
Old Mar 1, 2007 | 02:13 AM
Magnus213's Avatar
I had the same thing, started when the weather got really warm. It would hit the support struts for the deflector and retract. I asked them to look at it one day when I had my oil changed and 10K service done, and it took them the entire day to "reset the computer." I don't know what that entailed, but they must have disconnected my battery as my radio was goofy etc.
It has been working fine since then.
Old Mar 1, 2007 | 02:25 AM
TougeTerror's Avatar
Mine also did the same for two days this past summer. It would stop about 3/4 of the way when I rolled it in. And then it would stop and go back. I haven't had any problems since. Kinda wierd.
Old Mar 1, 2007 | 03:38 AM
hansta's Avatar
thanks guys for your info~ i'mo clean it and if it still don't work properly i'm gonna take the car in........guh...
Old Mar 1, 2007 | 05:13 AM
zScIoNtC's Avatar
I had the same problem and took the car in and they had it for a few hours they had to clean the tracks and re-lube them the grease had dried or been wiped off from cleaning. No big deal at least you know you can't cut your head off if you try to close the sunroof with your head out of it. LOL You'll live.
Old Mar 1, 2007 | 06:35 AM
hansta's Avatar
would this cleaning and and re-lubing something i can do?? it sounds pretty simple if i know what to use...
Old Mar 1, 2007 | 01:50 PM
ForceNut's Avatar
My boyfriend had the same problem for a little bit and then it just stopped happening. Very weird..
Old Mar 1, 2007 | 02:19 PM
pdstc's Avatar
mine a few times has not wanted to open at all. i'll press the button to open and it wont, i'll keep pressing it a bunch of times and then it will open, or sometimes it will start to open, but wont until i press the botton alot again...
Old Mar 1, 2007 | 05:29 PM
_NeXuS_'s Avatar
Yeah it has happened to me about 2 times. I did not close so I just tyurned off the car and turn it agaion and it would close.
Old Mar 1, 2007 | 06:24 PM
toyotapilot's Avatar
Mine was doping this, it was a simple thing for the dealership to clean and adjust it since it was under warranty. If you NEED to have it closed you can roll down your drivers window and gently push down in the deflector while you are closing the roof. It will close then. It's when it tries to push the deflector down itself that it senses too much forse and opens again....
yupinmytC
22
Jul 27, 2024 07:08 PM
BlingSlade
Oct 19, 2016 12:39 AM
vi3tb0i09
Sep 23, 2015 08:32 PM
atlantaemail
Sep 20, 2015 02:03 AM
alexbarspin
Sep 3, 2015 02:04 AM
