Wheel Bearings are Humming
Old Mar 1, 2007 | 09:16 PM
wooky1976's Avatar
Default Wheel Bearings are Humming
I've noticed this humming sound probably a few hundred or even thousands miles ago. I never really noticed it because I was usually had my music loud enough to drown the road noise. Anyways I talked to a mechanic while getting a state inspection and he agrees it's the wheel bearings.
I have 59,787 miles on my xB, does powertrain warranty cover this or is this a normal wear and tear. I never had to change a wheel bearing on my other cars with over 100k miles on it. So is this a premature wear and tear or is it because I driven this car to it limits.
Yeah I admit I haul close to 1k pounds of magazines I had to deliver twice over 100 plus miles. I have drive my xb over a ford which the water was right at the side skirts of the box. I've also had 19 inch wheels on it for a year because it was a dealer demo and yeah a dealer demo, everyone in town and everyone at the dealership drove this box till 11k miles.
So, how hard is it to change the wheel bearings? Do I have to change all four sides? Does both front and rear wheels have inner and outer bearings? Do I need to change the CV boot? Is there such things as a higher grade of aftermarket wheel bearings?
I guess the worst thing I heard that can happen is that my wheels would fall off eventually, is that true?
Old Mar 1, 2007 | 11:16 PM
jct's Avatar
jct
sad thing is the wheel bearing is a seal unit and it isn't serviceable and have to replace the whole unit instead of just the bearings pretty sucky imo
Old Mar 2, 2007 | 12:26 AM
wooky1976's Avatar
the whole unit like? the wheel hub? OMG maybe I can find some at the junkyard
Old Mar 2, 2007 | 02:08 PM
jct's Avatar
jct
the front has a front axle hub bearing along with a replaceable snap ring
the rear comes as a rear axle hub and bearing assembly
doing the rears will be easy the front i would let some body else to do it...
i wouldn't really trust some thing you'll find at the junk yard for bearings, never know what your gonna get...
Old Mar 7, 2007 | 05:18 AM
omarq's Avatar
the factory powertrain warranty should cover it.
Old Mar 15, 2007 | 10:56 PM
wooky1976's Avatar
The front wheel bearings cost $30 ea. and the rear hub assembly cost $300 some ea. This is wacked cuz parts alone would add up to about $800. Sad thing is that I now have little over 60k miles.
I heard the front bearings need to be pressed, can someone elaborate on this one. I am guessing it needs to be pressed to the hub assembly right? How hard can this be, has anyone done this yet?
I have jacked up my car and shooked each wheel and they're tight, nothing loose there.
What else can make this humming sound. It doesn't make a difference when I turn, so I guess the CV joints are ok right? The humming noise varies depending on the speeed, pretty much either when i'm slowing down or cruising above 25mph. At higher speed of course the road noise drowns out some, but I know it's there since I know how a new xb sounds like.
I guess i'm going to wait till a wheel falls off j/k.
Old Mar 16, 2007 | 04:22 AM
omarq's Avatar
Take it to toyota and see if they'll cover it as a "gesture". The factory warranty is 5/60k isn't it? if they say no call up toyota and tell them its been like that for the last 5k miles and you're real disappointed in the wheel bearings going out. Thats like Ford quality right?
Old Mar 16, 2007 | 06:57 AM
wooky1976's Avatar
I already passed 60k miles.
Old Mar 16, 2007 | 06:20 PM
omarq's Avatar
The warranty deadlines have some flexibility in them, but Toyota corporate can make that call. The point is to get it into the dealership and tehn ask them to see if they can make an exception. It'll only cost you their diagnostic fee to see if Toyota will save you $800.
Old Mar 20, 2007 | 05:30 PM
stickler64's Avatar
Is the humming more pronounced when you slow down? Sound like you're driving on studded snow tires? If so, It would indicate bearings. I had to have mine replaced with only 30k on my xb. 6 months after being repaired, the humming is coming back. I'll be taking to the dealership in the next few days. I'll keep y'all posted.
Old Apr 26, 2007 | 12:41 PM
stickler64's Avatar
Well, I took it in yesterday. Went to pick it up and the only thing they found was that my front tires were over filled. So, I got in the car, made it out of the lot and turned right back around. After alot of BS about how "aggresive" my Fuzion treads are and general tire care, I finally got the mechanic to ride with me. He's going to put another set of tires on it today and drive it to see if it still does this. He said that he ruled out the bearings because the were replaced 6 months ago. I said that they shouldn't have needed to be replaced at 30K, either. Maybe this is indicative of a larger problem. Does anyone have any ideas what could be going on?
Old Aug 11, 2007 | 04:25 PM
wooky1976's Avatar
Well, I found out putting about 50k miles on Kumho Ecstas made this humming noise as I got closer to wearing out the treads.
Old Aug 11, 2007 | 07:37 PM
jct's Avatar
jct
thats great news on not replacing the wheel bearings
Old Aug 12, 2007 | 12:09 PM
stickler64's Avatar
The noise on mine is worse. I'll have to get it in the shop, soon
Old Aug 24, 2007 | 06:21 PM
AKAvensis's Avatar
1k pounds loaded in a tiny little xB and you want Toyota to pick up the bill?
Old Aug 24, 2007 | 06:46 PM
SeanstC's Avatar
287.44 part number br930358 for the rear hub assembly at napa
Old Aug 31, 2007 | 02:37 AM
PBflorida's Avatar
If it's a wheel bearing problem you'd hear a hum getting worse at higher speeds and coming from one wheel. It's very unlikely that all 4 wheels had bearings go bad at the same time. you only need to change the one going bad, if that's what the problem is. 60k is much faster than average but not unheard of for front bearings, the rear bearings shouldn't be going bad yet.
Old Nov 5, 2007 | 05:29 AM
stellarhavoc's Avatar
I have the same hummin' issue past 25mph. Going into the shop tomorrow. Hopefully it's not too much to replace
65K miles, Tanabe DF210s, Monroe Shocks, 15" Toyo Proxes TPT: '04xA that i drive to the limit on a regular basis
Old Nov 7, 2007 | 09:13 PM
$220 for each assembly... replaced both rears. yay, no more drone... car feels much smoother
Old Nov 8, 2007 | 06:30 AM
Shakerhood's Avatar
Usually when Wheel Bearings are going bad it will moan when you go around a turn.
