Installed Koyo radiator
Old Mar 5, 2007 | 12:28 PM
Baine's Avatar
Default Installed Koyo radiator
Here are the pics of the old and new radiator. It took me and a friend about three
hours to install a Koyo radiator in my box on Sunday. We took our time and had to
drain the system an extra time because the drain plug needed an O-ring that it didn't
come with. There is a lot to dismantle to get the radiator out and we didn't want to
disconnect the A/C. I could not believe how small the old radiator was once we got it
out. It's only about 3/4" thick. The new radiator is over 1-1/2" thick and a lot more
open for air flow. The Koyo sure is shinny but once installed you can't see any of it.
Here is the old one
and here is the new one
Old Mar 5, 2007 | 01:49 PM
Sciond's Avatar
did you have an over heating issue?
Old Mar 5, 2007 | 02:08 PM
jdlong's Avatar
Nice man! I'm about to go through that same procedure. Did you run into any "issues" or did it go smoothly for you?
Old Mar 5, 2007 | 02:34 PM
Baine's Avatar
I wouldn't say that I was overheating, it was just running too hot when in heavy traffic
during the summer months in Atlanta.
The only issue was that I had to add an o-ring to the head of the old filler plug that I
had to salvage from the stock radiator as the new one only came with one of the two
required fill plugs. You also re-use the stock mounts. The A/C condenser is fairly
loose and moves easily to get the radiator past it without disconnecting it.
I drove 80 mph 33 miles to work this morning and only got the temp up to 180
degrees. Granted the outside temp was around 35. We will see on the trip home
as it will be over 60 by then.
Old Mar 5, 2007 | 03:51 PM
firesquare's Avatar
looks cool to bad you cant really see it though
Old Mar 5, 2007 | 06:31 PM
jdlong's Avatar
Thanks for the info... I'll keep that in mind. Let us know how the trip goes.
Old Mar 5, 2007 | 08:17 PM
Baine's Avatar
It's 59 degrees out and I just got home. The water temp got to 185 or so while driving
and jumped to 195 degrees at the first stop ;ight off the freeway. it took about 30 seconds
after I started rolling for the temp to return to 180.
Old Mar 6, 2007 | 06:03 AM
metal112524's Avatar
Man, i HATE!!!! when the cooling fan goes into friggin turbo mode or whatever. DAMND annoying, Down here, At night with no A/C running the damnd thing comes on. Just so damn hot.
Old Mar 6, 2007 | 10:56 AM
EasysBox's Avatar
so was it a worthwhile mod? does the fan turn on less frequently? are you running an F/I?
Old Mar 6, 2007 | 11:59 AM
Baine's Avatar
I believe this to have been a worthwhile modification. The real test will be summer in
Atlanta. This time of year the fan rarely comes on. I’m running a Blitz SC with a
CAI, header, and the stock RS 2.0 DC exhaust.
Old Mar 6, 2007 | 06:30 PM
bfurches's Avatar
I ran into the SAME exact problem with the o-ring, but i didnt notice it until after i had filled the radiator and began to purge the system
Talk about frustration, but it wasnt bad. Only took me 1.5. Maybe the xA is easier to disassemble.
...in the disassembly process:
The old radiator:
The new polished piece:
Just about done:
Final Product:
...after hooking up the scan tool i noticed the car was running between 35-55deg cooler on average! I will try to post some pics up, but this was such a good upgrade. The finish is top notch and the welds were amazing.
Nice Upgarde Baine! Hope i didnt thread jack too much lol.
Old Mar 6, 2007 | 06:40 PM
Baine's Avatar
No worries. It took me at least 30 minutes to go get the o-ring I didn't have on hand
and then my (very helpful) friend needed to take a few smoke breaks and we took a
beer break. And then I had to go for a test run around the block about twenty times
real fast. The time tends to get away from me somehow.
Old Mar 6, 2007 | 06:47 PM
bfurches's Avatar
How much did you pay? I got mine shipped for a little less than 250
Old Mar 6, 2007 | 07:15 PM
jct's Avatar
jct
when its time for me to get a new radiator thats what i'm going to get...
Old Mar 6, 2007 | 07:31 PM
Baine's Avatar
That's about what I paid. I talked Titan Motorsports down a bid from their advertised $260
Old Mar 10, 2007 | 10:07 PM
kimgt's Avatar
man, the guy with the Xa has the nicest garage i've ever seen.
Old Mar 12, 2007 | 12:50 AM
bfurches's Avatar
^lol
Thats my dealership. Its an 8 month old 8 million dollar facility.
Old Mar 12, 2007 | 05:36 AM
itsme's Avatar
lookin good baine glade to c your still moddin......
Old Mar 15, 2007 | 11:50 PM
arizonaturbo's Avatar
I had the same issue, but I just put some Blue RTV Silicon around the plug. Worked great!
tckid21
Mar 12, 2017 09:16 PM
YooItsJay
Dec 2, 2015 08:13 AM
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
