Need help with 35w to 55w conversion?
Old Mar 5, 2007 | 11:09 PM
Bluechualappa's Avatar
Default Need help with 35w to 55w conversion?
Need electrical guru's help!
Okay I have PIAA 002-X foglights. They have H3 bulbs that are 35w.
Well I want to change them to JDM yellow for when I get my 8000k HID kit.
I ordered JDM yellow luminic's in H3 but they only come in 55w so how can I make this work?
Will I need a bigger fuse or just plug and play and foget about it. Or is there more work involved?
Thanks
Old Mar 5, 2007 | 11:10 PM
Dakine's Avatar
Concept in Motion Crew
you can try running a wiring harness and get the power off the battery.
Old Mar 5, 2007 | 11:17 PM
Any other help? The wiring harness it came with goes to the battery and is grounded to the frame but it has a small white wire that connects to a fuse in the fuse box. IF I move that to a larger fuse would that accomidate the increase in wattage>?
Old Mar 5, 2007 | 11:35 PM
Nevermind. that wire goes to the fuse box is for the switch/auto cutoff feature. I have it wired to a 15 fuse.
So what would be envolved in doing a harness? and what would happen if I put the 55w bulbs in the 35w socket? Not enough power?
Old Mar 6, 2007 | 01:59 AM
eddo456's Avatar
you need thicker gauge wire and the wiring harness that came with them is probably too small. just wire up a new 16 or 14 gauge wiring harness and you should be fine.
Old Mar 6, 2007 | 07:04 AM
rocketgyrl's Avatar
55watts / 12vdc = 4.58amps (each bulb) X 2 bulbs = 9.16 amps
35watts / 12vdc = 2.92 amps (each bulb) X 2 bulbs = 5.84 amps
You're using 1.5 times the amount of current by switching to the 55 watt bulbs. I feel switching to a larger gauge wire would be a good idea. You've mentioned a 15 amp fuse is already in the circuit. According to the above calculations this should be close to ideal if you're using a pair of the 55 watt bulbs...though if you're blowing fuses after a few minutes, switching to NOTHING MORE THAN 20 amps would be OK. If you're still blowing fuses, upgrade to a larger wire gauge.
EDIT: I should add, I know nothing about bulb fitments, and am unsure of compatibility.
Renuco612
Sep 16, 2015 09:01 AM
mischman
Sep 15, 2015 03:38 PM
mav261
Scion tC 1G ICE & Interior
Feb 9, 2015 03:55 PM
jaspercanda
Dec 28, 2014 10:09 AM
