How many clicks does your handbrake go up before it engages?
Old Aug 27, 2004 | 01:01 PM
SpdLmtNA's Avatar
Default How many clicks does your handbrake go up before it engages?
I did a search, and really couldnt find anything about this. I think my handbrake clicks way too much...
Old Aug 27, 2004 | 01:43 PM
ImBack's Avatar
DelMarVa
Default I'd agree with you....
From the time I received my xA at the end of June, my emergency break has always gone well above halfway, very close to the top actually. I didn't really think to ask Pete my mechanic friend at the dealership why that was when I had it in for an oil change a couple weeks ago. I'll talk with him later this week and ask him if it's common. It could either be the brake cable out of adjustment or the rear brake itself out of adjustment. If I have time this weekend I'll pop the drums off and check myself if I can't get in touch with him.
Old Aug 27, 2004 | 02:45 PM
bCtC's Avatar
Big Sky Scion
i pull my e-brake up to where i normally would and when i let off the brakes, it rolls for a second, so i have to pull it up higher. i think it needs to be pulled up higher than normal. nothing major, i'm already getting used to it.
Old Aug 27, 2004 | 03:25 PM
JasonH's Avatar
Default Re: How many clicks does your handbrake go up before it enga
It goes up high, but it works. You get used to it quickly. I don't even notice it anymore.
Old Aug 27, 2004 | 03:37 PM
SpdLmtNA's Avatar
Great input... so anyone out there actually count the clicks yet... Im at work so i cant do it just yet
Old Aug 27, 2004 | 03:41 PM
JasonH's Avatar
I hope nobody does. It's a waste of time. Why does it matter?
Old Aug 27, 2004 | 04:49 PM
SpdLmtNA's Avatar
Well, if you pick up a full service manual (when it comes out for the tC)... it should tell you exactly how many clicks it needs to go up. That gives a mechanic or do it yourselfer an exact measurement... so when people tell me it goes pretty high, that doesnt help at all... why do you think it clicks... exactly for that reason. Its just an exact measurement. And, I really dont want my tC rolling into some other car on the days I leave it out of gear. :? So I wanna make sure its not doing anything abnormal... or that the e-brake is loose
Old Aug 27, 2004 | 05:57 PM
Ivben_Blown's Avatar
Looks like the service manual (RM1104U Page 137) says:
"Parking Break lever travel at 196N (44.1lbf) = 6-9 clicks.
My PB is fully set at 6 clicks and if I pull the lever moderately hard it will go one more click.
Hope this helps
Old Aug 27, 2004 | 07:49 PM
SpdLmtNA's Avatar
Hope this helps
Thanks for the perfect response
Old Aug 27, 2004 | 09:33 PM
iowagary's Avatar
Hope this helps
What service manual are you getting that info out of? It doesn't tell you that kind of thing in the owner's manual, does it? Do you work at a dealer? I always thought they should sell those things. I'm just interested in knowing all the little details.
Old Aug 27, 2004 | 10:07 PM
Hope this helps
No, I don't work for Scion/Toyota. I did a one day subscription from the Toyota Technical Information Service and downloaded everthing I could get. They've got the service manual, schematics and other interesting stuff for the TC. I'm not sure that the service manual is complete yet, seems like some things are missing (like parking brake, I can find the specs but not how to ADJUST them). Cost for a one day subscription is $10.
Also, if you do a search you can find a link for a portion of the manual that someone has already downloaded.
Old Aug 28, 2004 | 02:25 AM
nero_tC's Avatar
Default drivng with handbrake...
i don't mean to take over your post and I really didn't want to start another thread about the E brake.... but I had a quick question, does any damage occur if you drive with the handbrake for a couple minutes? i didn't notice but the service guy put the handbrake up for some reason. i drove a couple minutes at slow speed in the parking lot and over a few speed bumps.
is this bad for the brakes? or does it cause any type of damage? i've never done this before. i don't know if i'm paranoid or not but the brakes seem a little weak now. :?
Old Aug 28, 2004 | 02:38 AM
tcwannab's Avatar
it wears down ur park brake...if it feels weaker its probably because it is now
Old Aug 28, 2004 | 02:41 AM
nero_tC's Avatar
The parking brake? I was talking about actually braking when driving and stopping. It probably got a little weaker from this?
Old Aug 28, 2004 | 02:44 AM
tcwannab's Avatar
well im not a tc expert but most cars (that i know of) have a separate brake for the park brake thats usually a drum... its on the other side of the disc... i could be wrong but thats my take on it :?
Old Aug 28, 2004 | 02:50 AM
chucksu's Avatar
I know some cars with disc just have a built in parking brake. Its mounted as part of the normal caliper. The only style I have seen with a parking brake as a drum but is a rear disc is this cool set up for hot rods. They might use something else but I dont think they would because the more there is to put on the car the more it cost to make.
Old Aug 28, 2004 | 02:52 AM
tcwannab's Avatar
this is true like i said i could be wrong... if you really want to know i guess you could lift up the car, take off the wheels and take a peek
nero_tC's Avatar
so is it bad or not? and does it have any affect on the actual braking of the tC when driving?
Old Aug 28, 2004 | 03:09 AM
Short answer = NO
Parking brake (aka hand brake) uses two small shoes on a small brake drum within the center of the each rear rotor. The outer portion of the rotors are for standard disc brakes. You should be able to wear the parking brake shoes to the metal and it would not effect regular braking.
Old Aug 28, 2004 | 03:10 AM
tcwannab's Avatar
Short answer = NO
thats what i thought :D
