Regional - Deep South AL, AR, LA, MS
if u have installed a cold air intake please respond!!
Old Mar 21, 2007 | 01:13 AM
XB_XIII's Avatar
Default if u have installed a cold air intake please respond!!
do u have to remove the fender to install a cold air intake... all the pics i have seen show the fender removed..... is that just to show a good pick or do u have to remove it, thanks
Old Mar 21, 2007 | 01:14 AM
captainlaziness's Avatar
I didn't remover my fender, just the wheel.
Edit-
Whoops! xB, not tC.
Old Mar 21, 2007 | 01:21 AM
Tim_Carr's Avatar
Yeah do not remove the fender. It's way more work than needed, just remove the wheel and hold back the fender liner as you slide the tube into place. This is the best way to access the filter too. Unless you remove the bumper, this too is an awesome way to work on the front of these. Hope this helps you. Good luck!
Old Mar 21, 2007 | 07:52 PM
shorberg's Avatar
https://www.scionlife.com/forums/viewtopic.php?t=126678
Old Mar 21, 2007 | 07:59 PM
mitchelltc1's Avatar
wheel, and some of the plastic in the corner under the bumper, then bend back the plastic in the fender
Old Mar 23, 2007 | 02:45 AM
RS3xBToaster's Avatar
Wow I bought a F5 Fujita Cold air and didnt have to do anything but jack the front driverside up so i could get under the car to screw on the clamp to the filter.
ohh And by the way the F5 Fujita freaking rocks. I installed it yesterday took about 3 hours cause i lost a nut and had to wait for a friend to get off work to come pick me up to go buy one that fit LOL.
http://www.f5air.com/ <---- check them out if you own an xB.
Old Mar 23, 2007 | 02:51 AM
silver06's Avatar
OMG you lost a nut! You really need to be careful with that screwdriver.
Old Apr 9, 2007 | 11:53 PM
superfreestyle's Avatar
DeepSouth Scions
if you need an intake installed around this area I travel to jackson often and can assist. should take about 15 mintues,, depending on which intake you have
Old Apr 11, 2007 | 01:45 AM
Bubble2Box's Avatar
Jeff installed my K&N intake....was kinda freaked out when he started pulling the front bumper off....but he knows his stuff.....and this was a a Scion Show....
Old Apr 19, 2007 | 05:59 PM
Big_hungry's Avatar
I almost bought a cai but decided to go with a short ram. A lot less work to put on .
anyway back on topic. just do what they said you can reach into the engine bay area from the fender well. thats how I change my air filter
hampton1100
May 28, 2015 07:32 AM
AxRxP
Jan 25, 2015 08:40 PM
IGotThatOrangeToaster
Jan 19, 2015 02:35 AM
cacafria97
Dec 20, 2014 08:58 PM
hotroddelux
Dec 3, 2014 11:33 PM
