Regional - Great Lakes IL, IN, OH, MI, WI
Tuning special at Sound Performance in Bloomingdale, IL
Old Mar 22, 2007 | 04:38 PM
Scott8's Avatar
Default Tuning special at Sound Performance in Bloomingdale, IL
I am trying to get a bunch of Scions together to get their F/I or N/A cars tuned by Sound performance in Bloomingdale IL 60108
The more cars we get, the better the discount . Their shop is known to do a lot of sick Supras's and they do some great work.
check their site out http://www.spracingonline.com/default.asp
Normal tuning rates are $200 an hour, and it usually takes 2 hours with Emange ultimate.
post on here if you are interested
Thanks-Scott
Old Mar 22, 2007 | 05:26 PM
Robs_tc's Avatar
I'm down but I'm planning on doing tuning next week sometime. Unless this happens soon, I was going to go down to Speed Quest over in Waukegan, $125 an hour. Then again SP has a big reputation and I know they would tune it right. Let me know if and when you guys do something.
Old Mar 22, 2007 | 05:33 PM
Scott8's Avatar
I doubt we can get a big enough group in a short amount of time.
Old Mar 22, 2007 | 06:20 PM
Robs_tc's Avatar
I'm planning on doing a stand alone EMS soon with the engine build so I might still be around. The piggy-back isn't going to cut it when I start getting into higher rpms and boost.
Old Mar 22, 2007 | 06:26 PM
Scott8's Avatar
I am thinking the same with the EMS. But, I will try the Ultimate for now!
what piggy are you running?
Old Mar 22, 2007 | 06:38 PM
Robs_tc's Avatar
E-Manage Blue
Old Mar 22, 2007 | 06:40 PM
Scott8's Avatar
are you running a Greddy kit?
Old Mar 22, 2007 | 07:33 PM
Robs_tc's Avatar
The Dezod Signature kit: Innovative F2 54 T3/T4.
Old Mar 22, 2007 | 07:37 PM
Scott8's Avatar
I thought Dezod used an ultimate emange???
I know the Greddy uses the blue, that's why I asked.
I am almost tempted to sell my emanage and just go with the AEM EMS since I may be boosting it up, but $2000+ is a lot with my wedding 2 months away!!!
My fiance would kill me!!!!!
Old Mar 22, 2007 | 07:45 PM
Robs_tc's Avatar
If you’re aren’t going to mess with the redline or start getting crazy with the boost, assuming you’re running an 8.5psi wastegate spring, I’d say you’re going to be fine. There’s no sense in running a stand alone under bolt on conditions, although it would be perfect with a stand alone. It just doesn’t justify the cost. I thought about running Ultimate but no point in upgrading just to throw it out with the stand alone this summer. If you really want to run closed loop, get the Dezod part throttle black box. It’s cheap in comparison.
Old Mar 22, 2007 | 07:49 PM
Scott8's Avatar
the plan is to get the ZPI low compression block with all the internals and then add the stand alone and go to the track!!!
but that will be a nice 10,000 that I won't have until after the wedding.... These damn weddings get expensive!!!
Old Mar 22, 2007 | 08:18 PM
Robs_tc's Avatar
Oh, you want the complete stage 2 long block. The price tag they’re putting on that thing is really hard to look at. I’m getting all the internals and having the block build, saving a couple thousand and getting almost the same thing. I know ZPI has sleeved the cylinders on their toughest block. If they installed it and tuned it for free, I’d consider the engine but I’m getting a little ahead of myself. We’ll see what happens.
Old Mar 22, 2007 | 08:42 PM
Scott8's Avatar
maybe I can work that into the deal if I do go with them.
I was actually thinking of just doing what you did as well and save some money.
where are you getting the work done on your motor?
Old Mar 22, 2007 | 09:29 PM
Robs_tc's Avatar
Probably summer time to give the earliest estimate. I have my sights locked in on a LSD and the Axis lip kit. I might end up working something out with Paul over at Dezod on the block and the work. Otherwise there's a shop not to far that does great things with builds on imports and muscle cars. I don’t know how ZPI is coming up with that price, maybe they’re getting brand new blocks which would help to justify most of the cost. But hey, working in a machine shop myself, I know that labor isn’t cheap. But $7k for an assembled long block…. WOW!
Old Mar 22, 2007 | 09:36 PM
Scott8's Avatar
There is a core charge for the block, so I am guessing they are taking the stock block and doing the work on it and reselling it.
if I can get the work done for a lot less around here, I'll go that route. I started to piece it together and it came out pretty close, minus all the time to build it.
Any place you went to that has a great deal on some of the internals?
hampton1100
May 28, 2015 07:32 AM
corbmonster
Jan 24, 2015 05:22 PM
toyotaisme
Jan 10, 2015 10:24 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
nhw
23
Apr 1, 2004 01:58 AM
