Blowoff Valve Vacuum Source & Check Engine/VSC/TRAK OFF
Old Mar 25, 2007 | 11:00 PM
arizonaturbo's Avatar
Default Blowoff Valve Vacuum Source & Check Engine/VSC/TRAK OFF
My VSC, Trac Off and Check Engine Light come on after about 1/2 an hour of driving. I have been disconnecting the battery to reset it for the meantime. I do have a question though, when the check engine light comes on, does this actually disable the VSC and Traction Control?
Where are some of you pulling vacuum from for the blowoff valve. I tapped into the vacuum port behind the throttle body that taps into what seems to be an idle air control valve of some sort. I think this may be the source of the check engine, VSC and Trak Off light I am getting.
Any input would be appreciated!
Old Mar 25, 2007 | 11:07 PM
PakanaHerruus's Avatar
from my CEL i realized it does actually turn it off.. mine came on from the knn typhoon intake.. and i dont have the stock box to fix it.. reseting the ECU.. works...for a while.. and every now and then it shuts itself off.. you do anything different to it, to make it come on?
Old Mar 26, 2007 | 12:02 AM
Well,
I just installed the turbo kit.....
I read on www.clubxb.com that this is usually connected to an loose gas cap. I reset the ECU, tightened the gas cap and drove the car. It actually came back on after 15 or 20 minutes.
I came back to my house and thought about what it could be. I narrowed it down to two things:
1. My vacuum source for the BOV was incorrect.
2. I need to recirculate the BOV back into the intake track.
This is the hose where I tapped into for the vacuum source:
I am going to try and tap into the vacuum source on the side of the compressor housing and hook the BOV back up. It the code comes back, then I will try and recirculate and see if the code comes back.
Old Mar 26, 2007 | 02:21 AM
jct's Avatar
jct
you should tap it into the brake booster vacuum line much better source
Old Mar 26, 2007 | 02:29 AM
Thank you! I am definitely open for suggestions and will try that out.
Old Mar 26, 2007 | 01:17 PM
Simplyscion's Avatar
Team No Limitz
get yourself a golden eagle vacuum block and tap into the brake booster as duck dodgers mentioned...thats what I did with my setup...although, that may not fix the problem. All the turbo kits are known to throw codes...my box was lit up like a christmas tree
Old Mar 26, 2007 | 01:20 PM
ALEXB06PR1's Avatar
where is the brake booster vacuum hose let know plz
Old Mar 26, 2007 | 01:54 PM
Team No Limitz
look at the firewall on the driverside...find the brake fluid res...now on the firewall you will see something thats flat and round, almost like a plate with a hose coming out of it...theres your vac hose
Old Mar 27, 2007 | 05:28 PM
I bought some Contact cleaner last night, sprayed the MAF, drove the car for 1/2 an hour and then teh check engine light popped back on.
I iwll try the brake booster vacuum source this evening and hopefully this helps.
I borrowed an OBDII scan tool last night, but it doesnt support the J2534 driver. I still have not been able to pull a code.
mischman
Mar 31, 2015 03:16 AM
Exclusive
Jan 26, 2004 01:31 AM
Docsnuff
Jan 12, 2004 11:18 PM
TDogg490
20
Jan 9, 2004 12:10 AM
DJ_SpaRky
23
Jan 7, 2004 07:51 PM
