Back door skin moving...anyone with the same problem?
Old Mar 29, 2007 | 07:01 PM
GLN305's Avatar
Default Back door skin moving...anyone with the same problem?
After getting my 6 -12's in I have a problem with the back door outer skin moving about 1/2" and making the door handle rattle with it. I have done all the sound deading and sealing I can...any ideas what I can do now?
Old Mar 29, 2007 | 07:07 PM
dgHotLava's Avatar
turn the volume down...lol
the skin is thin and need some serious reinforcing. good luck
Old Mar 29, 2007 | 07:08 PM
Neothin's Avatar
lots of sound deadening
Old Mar 29, 2007 | 07:13 PM
HeathenBrewing's Avatar
Default Re: Back door skin moving...anyone with the same problem?
6 -12's....thats your problem!
Old Mar 29, 2007 | 07:21 PM
burstaneurysm's Avatar
Yea, 6 12"s is kinda overkill... for me, at least.
Old Mar 29, 2007 | 09:17 PM
TerribleTed's Avatar
6 12's OMG you know if you ever do find a way to keep the gate from flexing, that you are likely to flex somewhere else or perhaps even blow the glass out How many DB's does the system make??
There is a way to do this, I think. I think if you were to fabricate some steel bars to run from right to left across the gate skin surface inside the gate (maybe 2-4, 3/8" or so, square tubing pieces might be a good choice. These bars need to be bent and shaped to fit somewhat flush against the inside of the skin. They could then be glued in place with the structural adhesive body shops use to install door skins and sometimes roofs and 1/4 panels. It would be most secure if the bars were welded as well somewhere out near the ends (could be welded inside the door avoiding repainting the gate perhaps. This should work as long as the adhesive holds against the constant pounding of the bass. A more destructive but absolutely fool proof way would be the same as above but to weld the gate skin to the bars every few inches all the way across....this of course would require body working the result all the way across the gate and repainting the gate.
Old Mar 31, 2007 | 12:42 AM
bryman31's Avatar
6 12's??????????? i want proof, i want to see some pics!!!!!!!!!!!!
Old Mar 31, 2007 | 12:44 AM
sizzlinscion's Avatar
blowing the glass out is close impossible.
Old Mar 31, 2007 | 02:53 AM
Fran82's Avatar
There's not a whole lot you can do to the skin except similar to what Ted explained.
If the handle is the only concern, then your best bet is to take the whole handle assembly out and put foam/dampening material between all of the contact points.
Some things you'll probably just have to accept with 6 12s.
Do you have the finished pics?
Old Mar 31, 2007 | 03:03 AM
madmaxbb's Avatar
Back when we did big woofer wagons we got the foam eggcrate mattress pads and cut them up and stuff them in the empty metal cavity s it light weight and works good. dynamat can only do so much
Old Apr 2, 2007 | 03:45 AM
morningman's Avatar
am i think the 30 bucks i spent on egcrate did more than the 150 i spent i dynamat xtreme bulk pack
Old Apr 2, 2007 | 06:29 PM
UV7's Avatar
UV7
Not true. Having the glass literally explode out of the car is not likely, but it is not uncommon for windshields to be popped from their gasket. This is why the majority of the high-end SPL cars have Lexan windows that are riveted in place to support beams. This is done to maintain a proper seal within the cab of the vehicle. After all, a well-sealed cab will yield higher SPL than one that bleeds pressure from its seams. Popping the windows out of gasket would certainly cause a break in cabin seal!
Old Apr 2, 2007 | 06:32 PM
tCTaco's Avatar
Boy I was way off when I read the title of this thread!
Old Apr 2, 2007 | 06:39 PM
randomsuper's Avatar
at tctaco's post! too funny!
Old Apr 3, 2007 | 12:30 PM
GLN305's Avatar
Thanks for all the ideas everyone. I am going to be working on it this week and see what I can make work. An idea I have is to remove all the sound deadening from that area and them epoxy some flat steel rods in and then re-deaden. I hope that this helps a little, thos back door handles make some serious noise!
Here is a pic...although unfinished.
[/img]
Old Apr 3, 2007 | 12:42 PM
Is your wiper shaved?? On mine the worst noise comes from the wiper blade itself. Noise from the rear handle unit could be hard to solve. If you can figure out what rattles in the handle, you may be able to put some little pieces of adhesive backed foam in place to cushion the spot. Shaving the handle and using a door popper would work for sure but is obviously more invloved.
Old Apr 3, 2007 | 12:45 PM
Spiderbox's Avatar
holy lord
do you need to wear a cup when you listen to that?
Old Apr 3, 2007 | 12:52 PM
Ghost_1's Avatar
Originally Posted by Spiderbox
holy lord
lol almost spit up coffee on y computer screen reading that one!
BTW how many layers of sound deadning do you have. I know that in several other deadening post the guys end up doing 2-3 layers before getting good results. Also try the egg crate method someone was talking about. It's not much but every little bit helps.
Old Apr 3, 2007 | 02:34 PM
GLN305's Avatar
I actually have two layers of Sinus Live damping material everywhere. It is an asphalt based mat, but is much thicker than most others I have used and seen. As far as my wiper, it's not shaved, but it's not there anymore either. I used a small hole plug to fill he hole after removing it. Actually the least of my problem is the liftgate probably because it's covered in mat and four of the six subs face up. I am going to be messing with some ideas tonight to see what happens. I'll let you know what I come up with tonight.
Old Apr 3, 2007 | 02:40 PM
Ghost_1's Avatar
What about the side panels and roofing? did you dampen that too? I read that you said everywhere, but some people forget about the roof. It might not help a great deal but you never know.
