Replacing The Tail Lights, Need Help...
Old Mar 29, 2007 | 10:35 PM
HotChrisBFries's Avatar
Default Replacing The Tail Lights, Need Help...
I bought the Anzo tail lights and im having a hard time trying to figure out how to take off the stock tailights. I've used the search button (no joke) and people have said that they either had to take off or loosen the bumper to remove it completely. Can anyone tell me how to replace them? Ive seen 3 holes with the long screws where they screw into from the inside but I'm not sure if there is more to do then that.
Any help would be appreciated...
Old Mar 29, 2007 | 10:54 PM
falkor's Avatar
The bumper should be removed . Might be able to change them out bu loosening it but , I had to have mine removed . My Toyota Tech did mine . $ 30 . 00
I suggest removing it . Makes it simple ( if removing the bumper is considered simple )
Old Mar 29, 2007 | 10:57 PM
captainlaziness's Avatar
https://www.scionlife.com/forums/vie...asc&highlight=
If search doesn't give you the results you need for something like this, try the tech section.
Old Mar 29, 2007 | 11:07 PM
Thanks, I'll post pics sometime when they are in!
Old Mar 30, 2007 | 12:25 AM
OK I have MAJOR problems with the Anzo, the wiring harness does not match that of the TC!!! looking at at the stock wiring, it fits perfectly into the wiring of the car, but the Anzo's only have two black thingies that there are no connections for, i looked in my box that it shipped in and there is no adapter for them, there is just a piece of paper saying that if the +/- doesnt match up then switch it around. And also the paper shows the black plug, plugged into a brown piece that i do not have.
If anyone has installed the Anzo's themselves PLEASE help!
Old Mar 30, 2007 | 12:52 AM
Nevermind I figured it out, you have to take the wiring of the stock bulbs out of the stock light and plug the 2 black harnesses of the Anzo's into their place where the bulbs would normally go. then connect that harness with the stock white adapter into the TC as you normally would.
VERY confusing how they made these lights..... with no manual or hint of how to install these lights it can make someone who is new to the process very confused.
Old Mar 30, 2007 | 12:56 AM
jonathan110987's Avatar
pics?
i want these tails too
Old Mar 30, 2007 | 02:43 AM
Here is the pic i took with my cellphone at night after they've been installed, not the greatest picture, but it works
Old Mar 30, 2007 | 06:20 PM
ilovemytC's Avatar
I went throught the same thing. Got the bumper off, stock lights off, went to install and WHAAAA? Where do the plugs go?? So I immediately ran to the computer, pulled up SL and searched and found help. Congrats on your lights! Let us know if/when any problems occur. I have them too and love 'em!
Old Jun 28, 2007 | 12:26 PM
VeeDubbx's Avatar
are there any other threads that can walk me through this procedure, because i ran into the same problem yesterday while trying to install them, but i never actually got around to finishing it.
Old Jun 28, 2007 | 12:51 PM
Mid_Life_tC-risis's Avatar
Try this one from TRDSparks:
http://www.trdsparks.com/install/00016-21550inst.pdf
Used this to install my anzos. You don't have to remove the bumper, just pull out the sides.
Old Jun 28, 2007 | 12:54 PM
VeeDubbx's Avatar
yea, i got through that whole process, but when it came to the anzo plugs and wireing harness, i was confused,and still am lol
Old Jun 28, 2007 | 06:13 PM
ilovemytC's Avatar
hmmm, I guess I should have done a DIY, but I was in a hurry to get these in.
1. First take out the bulbs from your stock lights.
2. Remove the stock wire harness from the stock lights.
3. Also remove the wire harness from the Anzo lights.
4. Insert the stock harness into the Anzo light, making sure all wires are underneath the rubber grommet/seal so they don't get pinched against anything and you have a good weather seal.
5. Take the plugs from the Anzos and stick them into the bulb sockets from the stock harness.
6. Install both lights and test: on with headlights, brake, turn signals, flashers, etc.
7. If they do not light up, then you will have to turn the plugs around. If they still do not work properly, check your fuses and make sure all wires/and ballasts are plugged in.
Hope that helps!
Old Jun 28, 2007 | 06:18 PM
kanundrum's Avatar
*watches
Old Jul 8, 2007 | 10:16 PM
RS21128's Avatar
yo did anyone have fuse problems?!?! im tryin to put mine in now and the fuse blew..so i replaced it and it blew again! AAAARG
Old Jul 8, 2007 | 10:36 PM
SirPhobos1's Avatar
check the wiring of the tail light. it should go something like red, black, green, black. or something similar... one I had that was ef'ed up went red, black, black, green.
compare the two taillights and try to figure it out.
hope this helps!
Old Jul 10, 2007 | 02:46 AM
RS21128's Avatar
hey thanks for the advice..but me and my friend figured it out..the retartd who made the lights messed up on the wiring..but it was wierd cause i had to splice 2 wires and solder them together!! i got them on today finally and they r SEX
Old Jul 10, 2007 | 03:37 AM
VeeDubbx's Avatar
yes they are! congrats
Old Jul 10, 2007 | 03:42 AM
RS21128's Avatar
haha thanks man!!
Old Jul 10, 2007 | 02:18 PM
ilovemytC's Avatar
^don't forget to post up your tail light pics here! Congrats!:
https://www.scionlife.com/forums/vie...224&highlight=
