Scion tC automatic - Maintenance 60,000?
Old Apr 3, 2007 | 11:36 PM
aspire's Avatar
Default Scion tC automatic - Maintenance 60,000?
I have tC 05 automatic with 60,000 miles. I wanna go to my local auto service. What should I ask them to do/replace? Please advice.
Old Apr 3, 2007 | 11:43 PM
Hyghgynx's Avatar
Did you check the Maintenance Guide that came with your Manual?
That should tell you what needs to be done. Sorry, but I don't have mine in front of me right now.
Old Apr 3, 2007 | 11:49 PM
jroc's Avatar
i just did my 30,000 mile on my 05. still under warranty they told me they do the same maintenance for 60k. through deler an arm and a leg about $700. thank god i have tires for life. thats the only reason im keeping my warranty and keep up my service with the dealer. if not i would have done most of it myself
refilled all fluids
adjusted brakes
tire rotation and alignment
airfilter
in cabin airfilter
throttle body cleaning
fuel injector flush
replace wipers
tranny and engine oil change
inspect adjust drive belts
check battery clean terminals install anticorrosion pads
replace external fuel filter
flush and refill radiator
Old Apr 4, 2007 | 12:22 AM
707tC's Avatar
when you take your tc in for maintenance do they give you crap for being modded?
Old Apr 4, 2007 | 12:56 AM
aspire's Avatar
2Hyghgynx: thrown out my manual few years ago
2jroc: Thank you.
airfilter - DONE
in cabin airfilter - DONE
replace wipers - DONE
tranny and engine oil change - DONE
check battery clean terminals install anticorrosion pads - DONE
refilled all fluids - WILL BUY FLUIDS AT TOYOTA DSHIP
adjusted brakes - pads started squeaking after I replaced them
throttle body cleaning - ?
fuel injector flush
replace external fuel filter - WILL BUY FILTER AT DS
Interesting question.. how much will they charge me?
Old Apr 4, 2007 | 05:58 PM
jroc's Avatar
they never give me crap for my intake and exhaust. they actually did not charge me for the air filter replacement.
as for aspirethis is from the manual)
throttle body cleaning $70
fuel injector flush $70
alignment $80
inspect adjust drive belts-?
flush and refill-?(could be done yourself)
i cant believe i had to pay this i could have gotten some performance parts
jroc's Avatar
alignment $80
Old Apr 4, 2007 | 06:31 PM
aspire's Avatar
alignment $80
flush and refill- is there some special fluid?
Old Apr 4, 2007 | 09:43 PM
jroc's Avatar
have to drain your radiator. plug somewhere under the radiator. run water with hose through the radiator letting it drain to floor then refill with antifreeze and your done
Old Apr 5, 2007 | 01:14 AM
aspire's Avatar
2jroc: So easy, even a caveman can do it
2CTC
Sep 12, 2015 11:33 AM
mischman
Jan 14, 2015 06:07 PM
minter66
Dec 15, 2014 01:45 PM
lexobx
Scion xD Drivetrain & Power
Dec 7, 2014 05:52 PM
