oil pressure gauge?
Old Apr 25, 2007 | 03:07 AM
bigBOAT's Avatar
Default oil pressure gauge?
i know there has been many topics on this topic, and yes i have used the search button. but i am still a little confused on what else i need to get for it. do i need an adapter or a new fitting. help me out please! Im wantin to get my gauges installed by friday
Old Apr 25, 2007 | 03:33 AM
bigBOAT's Avatar
did not mean to put this topic i FI didnt realize it till just now
Old Apr 26, 2007 | 01:27 PM
THansenite's Avatar
The gauge should come with the required fitting.
Old Apr 26, 2007 | 01:30 PM
BrEaK_AwaY's Avatar
you need the gauge itself (get an electric gauge, not mechanical), and you need to get an oil block adaptor (it connects to your oil pan, and the oil filter connects to this). you sender unit for the oil presure gauge will connect to this block. run the wire from the sender unit to the gauge, and run your wires for the lights for the gauge, and your done
Old Apr 28, 2007 | 12:36 PM
bigBOAT's Avatar
will i loose all my oil with ^^^^ this method
Old Apr 30, 2007 | 03:37 AM
BrEaK_AwaY's Avatar
why would you lose oil? if you meen in the install process? yes. you might as well do an oil change when you do the install because you need to drain the oil.
Old May 1, 2007 | 12:16 PM
bigBOAT's Avatar
damn i just got an oil change 3 days ago
Old May 1, 2007 | 12:31 PM
jallamas's Avatar
I am not sure how the filter is situated for the TC but if you are careful you should only lose whats in the filter. So go buy an extra quart and you should be set.
Old May 1, 2007 | 12:45 PM
bigBOAT's Avatar
sweet.. is there any other ways to install it without loosing any oil??
Old May 1, 2007 | 01:12 PM
BrEaK_AwaY's Avatar
negative. your going to lose oil on the install. its not that big of a deal though IMO
Old May 8, 2007 | 06:01 AM
influence's Avatar
Default OFSP
Oil Filter Sandwich Plate.
Greddy makes them and a few other known companies
or you can buy a cheap one made in china imitation that could fail...seems like a simpe part....but is it??
influence's Avatar
Default OFSP
Old May 8, 2007 | 01:38 PM
yamaha16bw's Avatar
You could "T" off the where the stock oil pressure sender is. You might lose 2 or 3 drips of oil.
BlackKnight
Sep 15, 2015 06:42 AM
my06tc
Jun 25, 2015 12:18 AM
eric_m
79
Mar 17, 2013 12:21 AM
Minsk99
Mar 23, 2004 05:46 AM
Futureicon
Mar 22, 2004 01:02 AM
