turbos, exhaust, intakes
tC: GI: Dezod/APR X-1 EMS w/ 07-10 Harness
Old 06-18-2013, 02:47 PM
XPRTc's Avatar
Default GI: Dezod/APR X-1 EMS w/ 07-10 Harness
SOLD
Welcome!
I'm gauging interest in the Dezod/Allan Phillips Racing X-1 EMS that I purchased in August of 2010 for ~$1800. The unit is in good working condition, harness is in like new condition, and there are some scratches on the hard plastic case of the unit. *Includes a plug-n-play harness for 2007-10 tC's.
Looking for $1000 OBO
Quoted from https://www.scionlife.com/forums/sho...hillips+Racing
"Introducing the ultimate powertrain management system for the Toyota 2.4L. The X-One has been designed to take complete control of the injection and ignition systems to allow absolute management of powertrain operation without upsetting the factory ECU and its diagnostic systems. This enables the X-One to adjust every aspect of the powertrain calibration including rev-limiter extension since it drives the injectors and igniters directly as a true ECU.
Allan Phillips Racing and Dezod Motorsports has engineered a complete system that unleashes the reserved horsepower in your Toyota 2.4L powertrain.
A true parallel processing ECU with extended Rev-Limiter
Adjustable Soft-Cut Rev-Limiter Control (internally limited to 6500 RPM). Increased rev-limiter calibrations (up to 7800 RPM) are available from Authorized Dealers for highly modified race engine that are designed to handle the increased loading.
True Plug and Play Technology
A full wiring harnesses is used to adapt to system into the vehicle. It simply plugs into the factory ECU and harness using OEM connectors. Utilizes all factory sensors with the option of using high performance aftermarket sensors as well.
Complete Fuel Control
High-resolution map tables (20 x 24 cells) enable precision fuel adjustments during both closed and open-loop operation. Calibrations for oversized mass air flow sensors (up to 900 cfm).A sophisticated mass airflow based fuel controller senses OEM injection, desired air/fuel trajectory, WRAF sensor feedback and many other internal signals.
Calculates injector and igniter updates 200 times a seconds to provide high-bandwidth control. Forced-induction compensation up to 200% engine load and 7800 RPM. The table ordinate breakpoints may be adjusted to accommodate any range. Users tune the commanded air/fuel table with adjustments for trimming and dynamic fuel compensation. The calibration is entirely based upon engineering units (no fudge factors based upon injector duty-cycle, or MAF/ECT voltage). Advanced forced-induction auxiliary injection system controls secondary port and throttle injection. This control option enables the ability to keep the factory injectors stock with high quality performance, drivability and emissions. The oversized main injector function allows the replacement of the stock injectors as well. This control activates the secondary injectors based upon load calculations with a calibrate-able distribution between the port and throttle injectors (chemical intercooler feature).
Complete Ignition Control
High-resolution map table (20 x 24 cells) enables precision spark adjustments keeping the OEM knock control intact for durability. Mass airflow based load calculations accurately senses the cylinder conditions for precision spark delivery to 0.1’ (36 tooth accuracy). Spark advance and retard capability allow for modified intakes, exhaust systems and forced-induction configurations.
USB High Bandwidth Acquisition System
The power of USB unleashes the data acquisition capabilities normally found only in expensive high-end systems. XTune can capture over 100 parameters at 100 Hz for 100 minutes of data recordings.
18-Channel Auxiliary Measurement Port
In addition to the internal 18 sensor channels, the X-One includes an external 18-channel auxiliary data acquisition port. These channels are available for auxiliary measurements for pressure, temperature (RTD), thermocouples, UEGO and digital mass airflow sensors. All together, the XTune software package includes 36 sensor channels that allow for advanced data acquisition analysis. Included with X-One is a generic harness for connecting auxiliary measurements.
Dezod Motorsports notes on testing of this system over the past 10 months and over 30,000 miles...
We have extensively tested this system on a Dezod S1 Turbocharged 2008 Scion tC with 550cc & 850cc injectors for the past 10 months and 30,000 miles. The system is about as close to a stock turbo'd vehicle one can get without being stock turbo'd. The part throttle response, tunability along side the WOT control is unreal. It holds AFRs to 0.1 AFR point of accuracy. It's astounding actually!!
We here at Dezod Motorsports make this system come complete with a modified unit, a custom wiring harness and a start up calibration for your tC. We have done extensive testing on multiple boost levels from 5-14 PSI and injector sizes from the stock 310cc to 850cc injectors and all have worked excellently! So if you would like a base cal to start with, please let us know your injector size and we'd be glad to get you something to get started with.
Lastly, to further prove our point, that this unit works well, we had even taken this turbo tC on a 8 hour road trip. The tC had managed to get BETTER fuel economy than stock; with still running a 14.65:1 target AFR while in cruise like the OEM does. 4 miles/gallon more FTW!!!
In all, if you are looking to build a fairly wild street machine and keep the car as close to OEM turbo'd feel (like an SRT-4), then this unit is it! With rev limiter changes, top speed changes, built in shift light...It's the cat's meow."
Tuning Guide Thread
Customer Feedback on APR X-1 Thread
APR Software Download
http://www.aprpower.com/ecu_downloads.html
SOLD
XPRTc is offline
Old 06-20-2013, 01:43 PM
Souk's Avatar
Where in north east are you? Im located in boston,MA
Also what year harness??
781-475-6781
Souk is offline
Old 06-20-2013, 02:25 PM
XPRTc's Avatar
I'm located in Rochester, NY. I'm about 6 hours away from Boston. I've updated the original post to state that the harness fits 2007 to 2010 tC models.
XPRTc is offline
Old 06-28-2013, 01:17 AM
Black_label's Avatar
Still available?
Black_label is offline
Old 06-28-2013, 01:35 AM
XPRTc's Avatar
Yes it is
XPRTc is offline
Old 06-28-2013, 03:54 PM
el_scion's Avatar
Originally Posted by XPRTc
Yes it is
How much are you asking for ??
el_scion is offline
Old 06-28-2013, 07:06 PM
XPRTc's Avatar
Is the price not showing up in the first post?
I'm asking for $1000 OBO
XPRTc is offline
Old 07-28-2013, 12:26 PM
Jonny5ive's Avatar
Is this the same fuel managment as dezods s2 kit?
Sent from my Samsung Galaxy s4 using Tapatalk 2.
Jonny5ive is offline
Old 07-29-2013, 02:56 AM
XPRTc's Avatar
This is the unit that used to be offered in the Dezod S2 kit. Now, the AEM EMS standalone is offered in the Dezod S2 kit.
XPRTc is offline
Old 08-20-2013, 10:05 PM
XPRTc's Avatar
Bump
XPRTc is offline
Old 09-14-2013, 02:14 PM
XPRTc's Avatar
OPEN TO OFFERS
XPRTc is offline
Old 11-25-2013, 12:22 AM
XPRTc's Avatar
BUMP Any offers will be taken into consideration
XPRTc is offline
Old 02-25-2014, 03:10 AM
XPRTc's Avatar
bump
XPRTc is offline
Old 06-26-2014, 02:33 AM
XPRTc's Avatar
Bumps
XPRTc is offline
Old 09-02-2014, 02:36 AM
roadrunnergt's Avatar
still got that thing?
roadrunnergt is offline
Old 09-02-2014, 03:36 PM
XPRTc's Avatar
Yes I sure do
XPRTc is offline
Old 09-02-2014, 03:54 PM
Does this come with software?
Old 09-02-2014, 11:35 PM
XPRTc's Avatar
The software is free to download from Alan Phillips Racing's website. http://aprpower.com/ecu_downloads.html
XPRTc is offline
Old 09-26-2014, 02:13 PM
XPRTc's Avatar
SOLD
XPRTc is offline
krazylowgsx
12-18-2016 04:13 AM
garabaldy
01-31-2016 11:14 PM
Souk
05-12-2013 12:16 AM
RusWolf
11-24-2009 03:56 AM
i20solara02i
11-03-2009 02:30 PM
Quick Reply: tC: GI: Dezod/APR X-1 EMS w/ 07-10 Harness
