Scion O2 sensor signal biased/stuck rich bank 1 sensor 1
Old 12-28-2016, 03:36 AM
Julio3216's Avatar
Default Scion O2 sensor signal biased/stuck rich bank 1 sensor 1
What should I do? There is also an rpm problem . The rpms will go up and down at acceleration.
Julio3216 is offline
Old 02-05-2017, 02:44 PM
Kenh's Avatar
Default Same issue
I am having the same problem. Exactly. I wish I had some good advice at this time still working on it. Have so far been trying to work my way through the codes, I have replaced the MAF sensor, the O2 sensor-top one before the catalytic converter and the PCV valve, gas cap. Every time I replace one part for one code a new one comes up. I now have the cam positioning sensor to replace( but for some reason having trouble locating it).If anyone can point me in the right direction I would greatly appreciate it.
Vehicle has 343K on it and still runs great. Just recently started having issues with sensors.
I use it for a commuter car and drive over a 100 miles a day. Would like to get 500K out of it.
Kenh is offline
Old 02-06-2017, 01:02 PM
bbsciontc's Avatar
Wow, you must be the mileage champ here, haha. Unfortunately, the these problems can be tough to diagnose. Looks like you tried the obvious already. If you have a cam sensor code, I would start by diagnosing that first. Here is a diagram of it's location.
Attached Thumbnails Scion O2 sensor signal biased/stuck rich bank 1 sensor 1-cmp.jpg
bbsciontc is offline
