My 2AZ Build
Old 06-11-2012, 08:28 PM
  #41
Dim
Dim's Avatar
Waiting on a fuel pressure pulsator, my installer ordered and said i needed.... part is on back order from my local dealer.
Dim is offline
Old 06-12-2012, 12:20 PM
  #42
crush02342002's Avatar
Iv got a couple of used ones. Let me know if you need one
crush02342002 is offline
Old 06-12-2012, 04:03 PM
  #43
Dim
Dim's Avatar
Just got off the phone with my installer, he said the part should be in tomorrow according to the dealer. If not I'll let you know, appreciate the offer
Although he said he'll check other things if anything else is wrong but he can't start until it's in? Does that make any sense or he can start checking it?
Dim is offline
Old 06-12-2012, 04:38 PM
  #44
Dim
Dim's Avatar
Any recommendations on aftermarket clutches?
Dim is offline
Old 06-12-2012, 04:48 PM
  #45
Syldrin's Avatar
ACT 6 puck. looooove it.
Syldrin is offline
Old 06-13-2012, 01:38 PM
  #46
Makes sense that he can't start the car without that part unless he rigs something up
Old 06-13-2012, 03:21 PM
  #47
Dim
Dim's Avatar
Oooh ok, cause he said he wouldn't start double check the wiring on the FIC until he gets the pulsator in. I didn't think you need to have the car running to check up on it
Dim is offline
Old 06-15-2012, 08:33 AM
  #48
Dim
Dim's Avatar
Just got the car back today its running a hell of a lot better.
It's great for DD right now, but when I want to hit boost the clutch still slips bad. If I try and build up into boost it'll go, but I can see it slipping. The car isn't running as rich as before, but I can still smell gas when I leave the car. Hoping to get a new clutch by the end of this month or early next.
Dim is offline
Old 06-17-2012, 06:25 AM
  #49
Dim
Dim's Avatar
How is it for DD? Is there more effort to press it?
Please bear with me lol, which one?
http://www2.advancedclutch.com/14422...I_(2AZFE).html
Dim is offline
Old 07-01-2012, 04:46 PM
  #50
Dim
Dim's Avatar
I'm gettin' better gas mileage than my I/H/E setup lol. I was getting ~23-24 then.
Lights are flashing because I just started the car
Dim is offline
Old 07-06-2012, 11:06 PM
  #51
Dim
Dim's Avatar
Need some help guys. Got the clutch installed and my installer said it won't shift into gear while the car is running, but it can when it's off. He told me the the slave cylinder isn't extending out far enough. I already bought a extended slave cylinder pushrod, but I guess it's not enough? Or is there something else that can be a factor?
Dim is offline
Old 07-06-2012, 11:24 PM
  #52
Music City Scions
rhythmnsmoke's Avatar
New slave cyl.
rhythmnsmoke is offline
Old 07-07-2012, 12:38 AM
  #53
Dim
Dim's Avatar
Ah ok I'll ask the installer about that... also we tried to start the car, but it wouldn't start while in gear, moved it to neutral and it did. Once the engine was running it wouldn't shift into gear. It feels similar to the safety lock when trying to shift from 5th to reverse.
Dim is offline
Old 07-07-2012, 12:52 AM
  #54
Music City Scions
You just replace the clutch right? In that case, I would look into clutch adjustment. It could be engaging to low and not allowing it to go into gear. Had that issue before. I would look into adjusting the clutch pedal first.
Old 07-11-2012, 07:17 AM
  #55
Dim
Dim's Avatar
Getting the car tomorrow, turns out I needed a new slave cyl.
Size:  87.4 KBName:  imagejpeg_2.jpg
And XrsT emblems? :D
Woulda left 'em red, but they don't match the Xrs red, this is more glossy and the anodized 'rs' red
Dim is offline
Old 07-11-2012, 02:34 PM
  #56
Music City Scions
So my first instinct then...the more costlier one of course.
Old 07-11-2012, 04:57 PM
  #57
Syldrin's Avatar
Should of told them to reuse your OEM release bearing that act one is trash.
Sent from my ADR6425LVW using Tapatalk 2
Syldrin is offline
Old 07-12-2012, 04:29 AM
  #58
Dim
Dim's Avatar
Well I got the car back this morning, not sure what's could be the problem... but the car seems to be running pretty rich. I'm at a 10.6-11.7 afr while cruising, before the clutch job it was at 13.7-14.7 afr...
Also I hear some sort of metal 'squealing' sound... not sure what it is, can't source where it's coming from. But I'll try and figure it out tomorrow, any ideas also?
Dim is offline
Old 07-13-2012, 05:50 AM
  #59
Dim
Dim's Avatar
Dim is offline
Old 07-13-2012, 06:01 AM
  #60
sebbyxtc's Avatar
Hows the clutch? Did you adjust the clutch pedal?
sebbyxtc is offline
Quick Reply: My 2AZ Build
