* tC : Gauge Cluster LED Conversion Guide by LEDmod.com
Old 12-22-2014, 12:24 AM
  #241
xdejablu3x's Avatar
Originally Posted by Basebllstar
The gauge cluster will read what the gauge cluster reads. So if you buy a new one and install it, it will read what mileage that cluster has seen.
If you want to avoid sketchiness, i'd pull your original one and replace it with the purchased one for the few days you'll be doing the swap. Permanently swap the two and you're looking at fraud charges when you sell the car or lengthy DMV mileage changes and paperwork.
Thanks for clearing that up man. By the way do any of your eyes hurt with your gauges being any other color than red or amber? I like white/red or white/red/blue setups but they sure do hurt my eyes at night. Since I do a lot of road trips that could be dangerous. I've even read too that red and amber are the way to go because the lighting won't distract you at night.
xdejablu3x is offline
Old 12-23-2014, 04:41 PM
  #242
Basebllstar's Avatar
I would say the exact opposite.
Assuming you set the brightness to a reasonable setting, the blue/white contrasts well to the point that I'm not straining when I look at it like an orange or red would.
Basebllstar is offline
Old 01-17-2015, 03:41 AM
  #243
2006sciontcva's Avatar
hey are you willing to help me do my swap?
2006sciontcva is offline
Old 01-20-2015, 04:24 PM
  #244
Honestly, no.
It's a PITA and should something go wrong, I don't want to take responsibility. Look into LEDmod.com. They'll do it for you.
Old 01-20-2015, 04:31 PM
  #245
Honestly, no.
shipping it out is no option as im a vendor and i drive my car everyday ;/ was told you did it so i thought i ask
Old 01-21-2015, 01:03 PM
  #246
I did do it. You can as well. It's really not that difficult.
You can also still drive your car without the gauges.
I really am sorry I can't help, I've been really busy with work lately and don't have time to work on my car let alone someone else's.
Old 01-21-2015, 04:02 PM
  #247
i know its not really hard but i just never did something like this before and i dont want to screw it up.
and no you cant drive without the gauges as your mileage wont add up and you can go to jail for fraud if you try to sell the car
Old 01-22-2015, 02:48 PM
  #248
A few hundred miles won't make a difference, that law was written for people completely replacing their odometers with ones with lower mileage.
Old 01-26-2015, 01:48 AM
  #249
i drive all over va so it will be more like 1000 miles every 2 days lol
Old 01-26-2015, 12:29 PM
  #250
There's no way you drive 500 miles a day in your tC. If that's the case, don't put any money into your car; it won't last much longer.
Old 02-09-2015, 07:31 AM
  #251
5cion's Avatar
What size are the resistors? look to big to be 0603.....are they 1206??
5cion is offline
Old 02-09-2015, 12:38 PM
  #252
You have no idea what you are talking about and you are spamming. Stop.
Old 02-09-2015, 03:56 PM
  #253
mav261's Avatar
Anyone in the Fayetteville, NC area willing to do this for me?
mav261 is offline
Old 02-15-2015, 08:37 AM
  #254
5cion's Avatar
spamming? WTF u talking about, I was asking a question
5cion is offline
Old 02-19-2015, 03:11 PM
  #255
Humor me, post a picture of this 603 resistor.
Old 05-16-2016, 12:58 AM
  #256
kennyscion's Avatar
Default Is anyone still on here!!!? I have an issue need assistance asap
Grounding out cluster fuse as soon as I flip my headlight switch
kennyscion is offline
Old 07-02-2016, 09:38 PM
  #257
xile6's Avatar
Sounds like a short in one of the power wires.
I order a replacement cluster and i plan to do this mod once everything comes in.
xile6 is offline
Old 11-28-2017, 02:06 AM
  #258
Leviisme's Avatar
Default Hey
Originally Posted by engifineer
No that was a different guy (ledmods.net). Some of his customers are still contacting me to fix his crap
I would recommend, if you are doing this yourself, to try it without swapping the gauge cluster resistors first. I know most (including myself) do not want the gauges any brighter. Due to the higher voltage that the cluster leds run on, they will not be dim (they will be nice and bright) without swapping the resistors, so for some, it may be a bit bright to have right in your face at night if you do. I have my needles a bit bright now, which looks cool, but if I were driving too far at night it would probably get a bit distracting (which is why I make my backlit needle mods for others a bit more tamed down unless they want them super bright).
The main point is to know that it will look great either way. Dont confuse this with the HVAC though. You HAVE to do the circuit mod on it or it will be very dim. The difference is that it runs on a regulatd 8V supply stock while the gauge leds are running on battery power.
I have a 2006 Scion tC I want to swap the lights to blue on my speedometer cluster and HVAC...I live in Washington would you be willing to do it for me?
Leviisme is offline
Old 02-23-2018, 02:13 AM
  #259
Godsyn's Avatar
Hello, I am new here and was just wondering if someone could help me out. I have a 06 Manual tC. I followed the guide to switch out the LED's and resistors. Im positive that i soldered them correctly and in the right directions.
I alternated blue and pick PLCC-2 LED's. all of my lights work such as the high beams, turn signals, low fuel, seat belt, ect.. However, my fuel gauge, speedometer and rpm faces dont light up. As a result I am unable to see my speed, rpms and fuel level.
My guess is that maybe since i used both blue and pink LED's its too much? should i switch some resistors to higher ones?
Thank you in advance. Anything helps!
Godsyn is offline
Old 02-23-2018, 02:25 AM
  #260
xile6's Avatar
Did you replace the resistors?
and check to make sure the LEDs are fully solder. 1 not being solder correctly will effect the others.
xile6 is offline
Quick Reply: * tC : Gauge Cluster LED Conversion Guide by LEDmod.com
