Backwards Battery Polarity issue..
Old 04-06-2009, 05:19 PM
Scion Tuners
tC-Collin's Avatar
Default Backwards Battery Polarity issue..
So my friend was switching him battery with mine to check if his battery was dead, and hooked it up backwards on my car. A bunch of sparks later,
my car will not start, radio, interior gauge lights, windows/sunroof, LOCKS, all do not work. I've checked various fuses and such but have had no lead.
Can anyone give their .02 on this? Anyone ever done this? lol
__________________
tC-Collin is offline
Old 04-06-2009, 05:27 PM
GammaTNT's Avatar
That is strange, I did that to my tC too.
But everything was fine after I install my original battery back on.
____
GammaTNT is offline
Old 04-06-2009, 05:29 PM
O5_TRD_tC's Avatar
thats not good...
It should of blown the fuses
O5_TRD_tC is offline
Old 04-06-2009, 05:34 PM
ninjaionsobe's Avatar
Unplug the battery and remove the dome light bulb and start pulling fuses, in some Toyota a back up power system retains some power.
I would also disconnect the ECU then star t the car just once to drain power from anything else, then put it all back together.
___
ninjaionsobe is offline
Old 04-06-2009, 05:50 PM
SquallLHeart's Avatar
you blew lots of fuses
SquallLHeart is offline
Old 04-06-2009, 06:48 PM
BZinn1's Avatar
He blew most all the fuses.......
BZinn1 is offline
Old 04-06-2009, 07:34 PM
Scion Tuners
tC-Collin's Avatar
every fuse i checked was fine. is there like a main fuse or anything? i checked every fuse, under hood and under dash, that i thought it wouldve affected. all the ign fuses and ECU fuses. i just hope it wasnt an in-line fuse or the ECM
Old 04-06-2009, 08:32 PM
exactly how many sparks were flying around when your idiot of a friend was messing with your car?
if fuses aren't blown.. then you might as well sue the bastard.
you WISH they're just fuses... and i hope they are as well. check them again.
Old 04-06-2009, 09:03 PM
datdude1119's Avatar
x2
its gonna suck if you shorted any wires,, imagine trying to go thru every wire to find which one is bad good luck, start praying that its just a fuse
datdude1119 is offline
Old 04-07-2009, 12:19 AM
BZinn1's Avatar
ok did you check the fuses with DMM or just look at them.......if they all test good then you busted wires to the starter,ignition,or God forbid the ECU......your fuel pump pumping fuel,are you gettign spark....lots of areas to check....this is gonna take you some time to find it.
BZinn1 is offline
Old 04-07-2009, 12:59 AM
ack154's Avatar
Remember that there are fuses in the engine bay AND in the interior under the steering wheel.
ack154 is offline
Old 04-07-2009, 01:47 AM
Scion Tuners
tC-Collin's Avatar
Old 04-07-2009, 01:48 AM
BZinn1's Avatar
dont think there is a inline on the ECM.......know there is one in the box before it,but did not see one on the wire diagram mounted inline.....that could be it though.....
BZinn1 is offline
Old 04-07-2009, 02:14 AM
Go4shoped's Avatar
Look inside the fuse box under the hood. There should be a couple of fuses that are large and have a clear top. Those are the main fuses. One for the battery and one for the alternator. Or at least that's how it was on my Camry.
I haven't really looked at my tC's fuse box. But the last time I heard of someone doing this the ECU was fried along with many other fuses. But that was on a Hyundai. Let's pray Toyota designed the tC to be more idiot proof.
___
Go4shoped is offline
Old 04-07-2009, 02:17 AM
ok did you forget to give him the dead cell with all that went on mabey they got switch?
other then that can you get a volt meeter on the cig lighter outlet try to start tracing power ?
Old 04-07-2009, 02:18 AM
what car did the battery come from
Old 04-07-2009, 02:32 AM
kirk212's Avatar
Originally Posted by Go4shoped
Look inside the fuse box under the hood. There should be a couple of fuses that are large and have a clear top. Those are the main fuses. One for the battery and one for the alternator. Or at least thats how it was on my camry. I havent really looked at my tc's fusebox.
But the last time i heard of someone doing this the ecu was fried along with many other fuses. But that was on a hyundai. Let's pray toyota designed the tc to be more idiot proof.
Yea there are a few larger, clear cased fuses that are the main power dist. fuses. I blew my ALT fuse a while back by doing the same thing. There a pain to change, but thats prob your problem. It was weird because when I blew mine, some things worked, like the gauges would turn on with the ignition, but the car wouldnt start.
kirk212 is offline
Old 04-11-2009, 11:32 PM
Scion Tuners
tC-Collin's Avatar
thanks for all of your inputs, but it was, indeed, the 120a ALT fuse. So thank you kirk212. lol
Old 04-12-2009, 12:14 AM
kirk212's Avatar
No problem dude
kirk212 is offline
Old 04-12-2009, 12:23 AM
faux_ghost's Avatar
same thing happened in my g/f altima, her stepdad thinks he is car smart and f'd it up. he was telling her that she was gonna have to replace the ECU, battery, alternator....etc. when i checked it out it was only a $4 fuse that I had to replace....
i havent let him touch her car since then. lol
faux_ghost is offline
Quick Reply: Backwards Battery Polarity issue..
