CEL informal question
Old 08-30-2008, 08:17 PM
89db-'s Avatar
Default CEL informal question
So, after i installed my headers i've got a CEL
i've tried Antifouler method
longer antifouler
3 Antifouler
This type of o2 simulatorhttp://www.dsmtuners.com/forums/arti...simulator.html
and nothing worked ! the longest it still of it's when the o2 is plugged directly on the s-pipe.
what you guys (the one that the antifouler dsnt work) are you using ?
anybody tried this http://www.mkiv.com/techarticles/oxy...sor_simulator/
what about MIL eliminator ?
and www.o2simulator.com ?
there is seems to have not much info about them over here ![/url]
89db- is offline
Old 08-30-2008, 08:23 PM
tCtCtC's Avatar
use a L shaped antifouler
tCtCtC is offline
Old 08-30-2008, 08:26 PM
89db-'s Avatar
where to get those ? from help! brand?
89db- is offline
Old 08-30-2008, 08:28 PM
tCtCtC's Avatar
Click Here
That should do the trick. then if it still doesnt work hook up the ones you have til it does. dont forget to disconnect the battery between these. I have this from this seller, but not the L shaped.
tCtCtC is offline
Old 08-30-2008, 08:44 PM
paulky_2000's Avatar
This is precicely why I sold my header before ever installing it...
paulky_2000 is offline
Old 08-30-2008, 08:45 PM
89db-'s Avatar
i've ordered one ! ll see what happen ! you have it on your setup ?
89db- is offline
Old 08-30-2008, 08:46 PM
tCtCtC's Avatar
nah. i am/was running turbo so i never bothered
tCtCtC is offline
Old 08-30-2008, 08:49 PM
ditto
Old 10-08-2008, 12:50 AM
sc_irony's Avatar
Sorry to bump an old thread but i didnt wanna waste space and make a new one. Where is the OBD plug in located at so I can pull a code tonight when my buddy gets off work? I threw a CEL today
sc_irony is offline
Old 10-08-2008, 12:52 AM
89db-'s Avatar
under the steering column
89db- is offline
Old 10-08-2008, 01:12 AM
sc_irony's Avatar
OK so Im just gonna type whats goin on and see if anyone has any ideas. I just put my Injen CAI on last wednesday. This morning I go to start my car, it starts to fire up but then bogs down and dies. I crank it over again and it starts up, but a beautiful CEL light is glowing at me. Car seems to run pretty much like normal, but once this afternoon at a stoplight it was holiding at 750rpm and then started bogging and tried to die. I came home disconnected the battery let it sit for awhile and then went out and reconnected everything. I started it up and the CEL went away and it seemed to be idling fine. I let it idle for around 6 minutes and then the fan kicked in....but when the fan kicked off the motor shut off with it and the CEL came back on? Im gonna go to autozone and have them pull the code because I dont wanna wait for my buddy to get off work, anyone have any ideas? Also where can I find what the code is when autozone gives it to me? Sorry for the long read, thanks again
sc_irony is offline
Old 10-08-2008, 02:05 AM
sc_irony's Avatar
So I just got back from autozone, the guy said it was a first bung 02 sensor problem, and that it was running rich? I bought MAF sensor cleaner hoping that will help...anyone have any input?
sc_irony is offline
bootlgr
01-26-2016 01:22 AM
Greg S
05-28-2015 12:46 AM
Scionxa180
03-13-2015 04:39 AM
TotalChaos
13
02-04-2015 10:24 PM
elzy0000
01-16-2004 04:31 PM
Quick Reply: CEL informal question
