good idea buying used springs?
Old 10-26-2010, 03:57 AM
uhsentc's Avatar
Default good idea buying used springs?
is it a good idea to buy used springs? would they have wear on it?
uhsentc is offline
Old 10-26-2010, 04:55 AM
shadow_shifter's Avatar
I wouldnt reccomend that cuz depending on the brand (cheap ones or good ones) the have a tendency to sag after the have been on a car for sometime.. and like you said they could have wear on them. Its all up to you though if they are a good brand and look good to you and the person you are gettin from you know and trust... then go for it!
shadow_shifter is offline
Old 10-26-2010, 05:11 AM
uhsentc's Avatar
hmmm buying them off an SL member in the classified section. TRD according to him 6k miles
uhsentc is offline
Old 10-26-2010, 02:46 PM
Spicy_McHaggiz's Avatar
There is ABSOLUTELY NOTHING WRONG with buying used springs. Springs are not an item that tends to wear out easily. Cheap springs will sag, however most name brands for this car will not sag. Settling is not sagging. The only "wear" that you can really get on springs in its lifetime will be from bad installation. (Stress risers mainly) Most springs will last for the life of the vehicle.
TRD springs are great springs. They are made by Toyota, and will not cause problems. And with only 6k miles on them, they are barely even getting set in.
I've bought used springs several times, never once had a problem with any of them. If the price is right, there is nothing wrong with buying used springs.
Spicy_McHaggiz is offline
Old 10-26-2010, 04:16 PM
SuperXero's Avatar
they are made by eibach
SuperXero is offline
Old 10-26-2010, 04:31 PM
headlessmunky's Avatar
I have Htechs, they had 25k-30k miles on them. I have put like 1k miles on them, no sag and ride great.
headlessmunky is offline
Old 10-26-2010, 04:57 PM
burstaneurysm's Avatar
Well made springs will last a very, very long time.
burstaneurysm is offline
Old 10-26-2010, 05:50 PM
TOUCHE! None the less, Eibach is an extremely good company.
Old 10-27-2010, 02:25 AM
xdejablu3x's Avatar
there is nothing wrong with buying used springs. you can buy springs that have 50K miles on them and they'll still work just as good. though quality does have its place so keep that in mind. but really...only way your springs are going to wear out is if take them off the car and bang them around and try to make it a slinky. its some what better used anyways cause their broken in. other than that they'll last well over the cars lifetime.
xdejablu3x is offline
Old 10-27-2010, 11:58 AM
a_german_named_hans's Avatar
nothing wrong with used springs. Bought mine used. Nothing wrong with them.
a_german_named_hans is offline
Old 10-27-2010, 12:22 PM
SW_08's Avatar
what they all said
SW_08 is offline
Old 11-07-2010, 09:13 PM
edwardl's Avatar
Eibachs usually have a million mile warranty so no, you won't have any problems with used springs unless the previous owner was stupid and cut/heated them or something like that.
edwardl is offline
yhwhdesign
02-06-2015 04:58 AM
BrokenTC2
01-27-2015 03:32 AM
Scionxa180
Scion xA Aero & Exterior
12-17-2014 04:33 PM
carid
12-16-2014 09:53 AM
scionboxrox
11-24-2014 06:38 PM
Quick Reply: good idea buying used springs?
