Scion tC 2G ICE & Interior In-car entertainment and electronics...
How to Remove Vents to Paint..
Old 01-16-2012, 08:24 PM
devanb3's Avatar
Default How to Remove Vents to Paint..
Been asked a lot how to do this so here we go
Before you do anything, know that I am not liable for any damage to you or the car. You will be working around your air bags and they are not always stable.
START HERE.... Remove Negative battery terminal. Do not proceed until this is done.
Start with the CD player bezel, then go to the right to pull the trim above the glove box. Next, open the glove box, squeeze the sides and remove the glove box.
While your in there, you can install a cabin filter in the white tray behind the space where the glove box was.
Next, move over to the steering wheel. Remove the bezel over the Speedo (pull straight out). Then the plate holding the controls for the mirror.
Next, there will be an array of Phillips head screws across the dash... remove them. Afterwards, pull lightly on the front pillars.
They are held in place by a black holding pin. To release them, turn the pins 90 degrees and pull off. There are two of those clips.
After they are released, pull up and out. Next, look above where the glove box was and there will be a yellow clip for the passenger side air bag.
Undo the connector and remove (want to say it was 12mm, might have been 10mm) the bolt holding the air bag to a metal bar.
After that bolt and all Phillips head screws have been removed, lift upward and pull out. The entire dash (with airbag) should come out.
Then you can take out the vent trim using a small flat head by releasing the clips around the vent.
You have to remove some Phillips head screws holding the A/C duct in order to get some of the vents.
After that, paint away.
I'll add pictures when i do this to my newer tC but it may be a little bit
This is a thanks to Superpickel who told me how to do this a while back
__________________
devanb3 is offline
Old 01-18-2012, 03:34 AM
op4dc4's Avatar
I tried to do it but I found some of the phillips but I dont know exactly where they are and how many of them there is .and I tried to turn the 2 airbag clip to 90 degres but I never find them .If some one can post some pic it will be really appreciated have a nice day everybody.
op4dc4 is offline
Old 01-18-2012, 03:38 AM
devanb3's Avatar
i may try to remove mine tomorrow if not ill deff have it apart this weekend so ill let you know what i figure out but like i said earlier its been a min since i did this so it may not be spot on instructions
devanb3 is offline
Old 01-19-2012, 03:28 AM
Superpickel's Avatar
most pleased to be of service...
Superpickel is offline
Old 01-19-2012, 04:17 AM
devanb3's Avatar
I put a shout out to you I may have just miss spelled it
devanb3 is offline
Old 03-02-2012, 05:07 AM
HockTc2011's Avatar
any one have any luck this is something that i have been wanting to do to put lights in my vents an run my radar detector wire down though the dash . but i don't know how ? im not in a hurry but would like to know when you guys get it done . Thanks
HockTc2011 is offline
Old 03-03-2012, 09:14 PM
devanb3's Avatar
I'Il be redoing it on my new tC here within the next week or so and ill try to take pics if it would stop raining i would do it now.
__________________
devanb3 is offline
Old 06-16-2012, 02:48 PM
scionchicop's Avatar
Update w/pics please...
scionchicop is offline
Old 11-08-2012, 03:12 AM
ProjectTC2's Avatar
My DIY ^ :D
ProjectTC2 is offline
Old 11-14-2012, 12:31 AM
devanb3's Avatar
Originally Posted by ProjectTC2
My DIY ^ :D
since your DIY is not stickied can i put your pics for this portion in this how to
devanb3 is offline
Old 03-24-2021, 10:30 AM
MastyrOfPuppitz's Avatar
Never see threads followed thru with pics here.
MastyrOfPuppitz is offline
Old 03-24-2021, 02:14 PM
Super Moderator
SuperMod
MileHightC's Avatar
Pretty good odds that you won't either on an 8 year old thread...there may still be some pictures up on some of the threads if you do a little searching, although a ton of pictures were lost when Photobucket moved to charging for access to photos hosted there,
MileHightC is offline
Old 03-24-2021, 02:54 PM
Administrator
Administrator
MR_LUV's Avatar
[QUOTE=MastyrOfPuppitz;4306135]Never see threads followed thru with pics here.[/QUOTE]
If you take the time to SEARCH or Know Where to Look, you can find pics here:
Sticky DIY - Interior Trim Removal!
MR LUV
__________________
MR_LUV is offline
Old 03-24-2021, 07:19 PM
[QUOTE=MR_LUV;4306138]
MR LUV
__________________
Before I was a member I used the search for my research. Viewing so few pics I thought registering would maybe show something I couldn’t see otherwise. I was wrong. And almost everything I type is either wrong, leads to no updates, or negative replies. This place is less helpful as a member than it was before so. Not very welcoming at all.
Old 04-05-2021, 01:28 AM
MR LUV
__________________
Thanks for helping a noob cracka out!
brianinvt
Scion xD ICE & Interior
08-14-2012 03:24 AM
firstkingofbeer
06-06-2008 05:24 AM
origanis
03-18-2006 09:07 PM
badger2
01-16-2006 04:41 AM
rmrc51
10-25-2004 09:57 PM
Quick Reply: How to Remove Vents to Paint..
