Cabin Air Control removal
Any tips on how to access/remove the cabin air controls? The temp. control/rear defroster **** got pushed into the dash, and all I've found are instructions on how to remove the center console below, or the radio/dash above.
pull the waterfall off, then pull that piece off. Might be some screws around the cup holder area, can't remember if the temperature control panel makes it down that far. It is simple though, just start pulling.
I just did this today. You pull kind of down and towards the back of the car grasping the edges of the piece you want to remove and it will pop out nicely, no need to bend panels etc. I think it's technically designed to remove from top down (first over the head/air vents) but I did it from bottom up with a little care. Also, if you take out your glove box you can reach inside and help yourself out a bit. Running wires? Up to anything fun?
airmankevin1
Feb 14, 2018 01:23 PM
10gxiong
Feb 21, 2015 12:53 PM
randompacking
Jan 28, 2015 11:43 AM
