Will This Wheel fit? (Guide to Offsets and more)..
Old 08-01-2015, 12:56 PM
  #501
cha2ga's Avatar
Originally Posted by nastytc
You are all clear man! I'm running 18x9.75
225/45/18
I don't rub.
Thank you. This is very good news!
The et30 won't be an issue?
cha2ga is offline
Old 08-01-2015, 02:54 PM
  #502
nastytc's Avatar
I have a 26 offset I think that's what it is I got closest I could to stock
nastytc is offline
Old 09-03-2015, 10:14 PM
  #503
DaYUUM/Scion Evolution
KidJustin's Avatar
took the original post and made a full blown article with pictures and colors:
Idiot's Guide to Wheel Fitment Basics
KidJustin is offline
Old 09-04-2015, 02:57 AM
  #504
carbinefreak's Avatar
Wow looks nice its a shame I had to do real math in excel to get mine perfect lol.....
carbinefreak is offline
Old 09-22-2015, 06:33 PM
  #505
Jayrdee's Avatar
Figured I would post in this just to share some info.
18x10 et30
225/45/18 tires
No fender rolling needed, no excess rubbing either. (only rubs the fender liner clips whenever i make a hard turn)
Jayrdee is offline
Old 09-26-2015, 06:58 PM
  #506
jcraff3's Avatar
Very good to know man. I'm soon looking at 18x8.5 with 15mm spacers in the rear, thought there would have been more issue,
I'm at 2.5 probably plan 3-3.5 with new setup.
I'm also going 1 size smaller on the tire, however how low are you?
____
jcraff3 is offline
Old 09-29-2015, 04:23 PM
  #507
Jayrdee's Avatar
Default Awarded 5 Year Badge
I'm at 2.5 probably plan 3-3.5 with new setup. I'm also going 1 size smaller on the tire, however how low are you?
Yeah, you'll definitely be good. smaller wheel and a smaller tire. and I honestly don't know how low I dropped it LOL.
I just kept lowering it until I thought it looked good. Id say somewhere between 3.5-4 inches. I maxed out the rears but still have one lock ring/perch thingy
____
Jayrdee is offline
Old 09-29-2015, 07:32 PM
  #508
jcraff3's Avatar
I just kept lowering it until i thought it looked good. Id say somewhere between 3.5-4 inches. I maxed out the rears but still have one lock ring/perch thingy
Oh OK cool. with the slight wheel gap you have i would have guessed 2 inches. I'm 2.5 right now and have about the same gap.
Also the only coil kit so far I know of that goes 4 inches if you take the rings out are the ISC Coils I'm currently on.
K Sport bc or anyone usually only hit 3 but who knows it's still good info to have.
Crazy plans for my car next year so Thanks.
____
jcraff3 is offline
Old 10-07-2015, 07:00 PM
  #509
AZtC89's Avatar
Hey guys! A pothole has taken the life of one of my TRD wheels recently. I'm now in the marked for a full set of new wheels and tires. I've done quite a bit of researching, but I'm overly cautious and like to get thing right the first time, so I figured you could put my mind at ease.
CURRENT SETUP
Wheels:
Brand & Model: TRD PTR56-21110
Diameter: 19"
Width: 8.0"
Offset: +35mm
Tires:
Brand & Model: Goodyear Eagle F1 Asymmetric
Suspension:
TRD Lowering Springs
PROSPECTIVE NEW SETUP
Wheels:
Brand & Model: Enkei Raijin
Diameter: 18"
Width: 8.5"
Offset: +35mm (+38mm also available)
Tires:
Brand & Model: Continental ExtremeContact DWS06
Size: 245/35ZR18 or 235/40ZR18
Suspension:
My goal is not to avoid tire rub in the front while getting flush with the fenders. I'm open to rolling the fenders, but would prefer to avoid it if I can. I won't be doing staggered sizing for the rear. I'm thinking a mild tire stretch would be acceptable for additional clearance if necessary, but I also want tire longevity, so if there is a best-of-both-worlds recommendation anyone could make I would greatly appreciate it. This is the first set of wheels I've ever bought so the measurements and math are boggling my mind, lol.
AZtC89 is offline
Old 05-02-2016, 01:56 AM
  #510
Cmay44's Avatar
So I have read as much as my brain can take. I'm new to the Scion world coming from German vehicles.
I have a 2012 tC. With that, what's the best size wheel to run without rubbing or fender Rollin?
I'm going to drop it at least 2". Any suggestions would be great! Wanting to go with a concave wheel no lip.
____
Cmay44 is offline
Old 05-23-2016, 02:42 PM
  #511
Madmaxxx's Avatar
Default RS8.0
hi, If I go with a
18×9 +25mm/245/40/18
18×10 +25mm/265/40/18
My RS8.0 is just drop on TRD
Someone have the same setup ? Will this fit ?
Thanks
___
Madmaxxx is offline
Old 05-23-2016, 10:40 PM
  #512
tC_toph's Avatar
Originally Posted by Madmaxxx
hi, If I go with a
My rs8.0 is just drop on TRD
Thanks
https://www.scionlife.com/forums/sci...ite-tc-232685/
This guy has a similar wheel setup, he had to pull and roll his fenders.
tC_toph is offline
Old 03-09-2017, 04:35 PM
  #513
ryanbl95's Avatar
Smile
225/45/18
I don't rub.
hey i need help finding right offset and tire size
ryanbl95 is offline
Old 03-10-2017, 01:36 AM
  #514
Administrator
Administrator
MR_LUV's Avatar
Originally Posted by ryanbl95
Hey, I need help finding right offset and tire size
Check out: Sticky tC 2G+ Wheel, Tire and Offset Calculator
It pretty much have everything to do your own Calculations for the right offset and tire sizes. Feel free to Experiment with it.
Also Check out located in the Center just Above all the Posts ▲▲ LOOK UP! ▲▲ Check out the Scionlife Tire/Rim Calculator▲▲ LOOK UP! ▲▲
__________________
MR_LUV is offline
Old 08-07-2017, 05:05 AM
  #515
SC_tC2's Avatar
Default If someone doesn't mind helpin me out...
I have TRD wheels (19x8.0 +35, tires are 235's, I don't recall the Aspect Ratio and I plan on dropping my car on D2 coils fairly soon. I also have 10mm and 20mm spacers I planned on adding too.
I'm not excited about rolling fenders but I will if I have to. If someone doesn't mind letting me know how well this set up works and if I'm gonna have rub and end up needing to roll my fenders that'd be great.
____
SC_tC2 is offline
Old 06-25-2020, 05:24 AM
  #516
sctc1410's Avatar
Default New Wheels
So I just ordered some Konig 18×8s with +45 offset if I'm reading things correctly from the thread I should be OK but I'm not entirely certain.
Anyone running anything similar?
sctc1410 is offline
Old 06-25-2020, 02:56 PM
  #517
drizzoh's Avatar
They /should/ but they won't fit very flush. If you want to get more flush see if you can cancel and order that same wheel in a 25-30 offset. Generally you want to order lower offset and not higher to avoid inner clearance issues.
drizzoh is offline
americandollar
02-17-2007 03:03 AM
smilezdc
Scion tC 1G Wheel & Tire
24
01-25-2007 04:31 PM
kdepew
08-01-2006 01:15 AM
roflitzjinno
9
04-23-2006 02:37 PM
bbsukidesu
08-13-2005 06:14 PM
Quick Reply: Will This Wheel fit? (Guide to Offsets and more)..
