Serious question...NEED HELP PLEASE!!!!!!
my 06 xb will not shift into overdrive until my cool temp light has gone off..as soon as the blue light goes off it shift to the final gear...no check engines lights are on.. just wondering if anyone has an idea....please help
normal??? im not doubting you.. but i dont think it did that before..is there anyway you could be alil more specific..yours does this?
Originally Posted by screamnchikn
Yes thats normal.
https://www.scionlife.com/forums/viewtopic.php?t=160133
its normal, its just that your car is not completely warmed up untill
after the blue termom. turns off
It's like an echo chamber in here... but yes, it is completely and totally normal. Don't worry about it.
Re: Serious question...NEED HELP PLEASE!!!!!!
Yup, what they all said. LOL
I'd happened to read it in my manual before cold weather so I knew it was to happen. A bit aggravating, but that's how it is setup.
What they said. Shortly after I started reading this fine board last fall, this topic was covered. It is a bit strange, but normal for our boxes.
It is normal for almost any car if the temperature is cold enough. Some only do it based on a threshold of how cold it is compared to operating temp. Some simply put a time span in the ECU/PCM such as it will not enable 4th until 60 seconds has passed, etc.
Mine is even slower going into 3rd right after i crank it. It's a bit of a pain when it's cold but knowing it's there to save the works makes me feel better.
normal, just give the tranny time to warm up, normal toyota thing, but you could always get a 5 speed and then you will go into any gear you want it to, hahaha
Normal, covered many times before on ScionLife, it does it to protect the engine (and automatic transmission, if equipped).
This and many other important things are covered in the owners manual you were given with the vehicle.
Read it. Really! You will learn a lot about your new car.
Tom
Tom
Sgtfluffy16
Regional - Northeast
07-28-2021 10:32 PM
