Wheel Hub/Hub Assembly
Old 05-04-2016, 02:29 PM
missing_image's Avatar
Default Wheel Hub/Hub Assembly
Okay so on my 2005 xB, I'm getting the rumbling/vibrations usually associated with the wheel bearing going bad.
Problems
Every time I look up the front wheel hub assembly I get a 5 lug one when my car is currently equipped with 4 lugs.
Every time I look up the front hub bearing (which would have to be pressed in), I get bearings with various size outer races.
Question
If you've had to replace the front bearing and/or hub assemblies, what parts did you use? I'm not looking for anything fancy, honestly there's a 15 dollar bearing for sale on CarId that I'd love to get pressed in but I have no idea if it (or anything else on the site will actually fit).
missing_image is offline
Old 05-04-2016, 06:35 PM
Super Moderator
SuperMod
MileHightC's Avatar
Try this...Scion xB Front Wheel Bearings
I wouldn't buy the cheapest one you can find as it's a job you only want to do once...I'd go with Timken or SKF if it were my box.
MileHightC is offline
Old 05-28-2016, 05:36 PM
lobo9er's Avatar
I just did my wives 2006 scion xb wheel bearing it is a job you don't want to do twice... there is a video on youtube of a toyota camry with similar wheel hub with the right tools and little experience it probably isn't as bad of a time as I had took 3-4 hours for me learning as I went with a friend. The biggest problem we had was removing the old one and with the proper "puller" it would have been easier I could tell.
lobo9er is offline
